You're going to like this one. Apevia 450W @ Hardware Secrets
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    http://www.hardwaresecrets.com/artic...-Review/1212/1
    Fail. Fail. Fail. Fail. And did i mention fail? The best of Solytech. The PCB layout is super clean... but that's about where it ends. I'm not spoiling the rest of the surprises. Enjoy the read.
    A working TV? How boring!
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: You're going to like this one. Apevia 450W @ Hardware Secrets
    Oh 'Deer' me...
    Let's play Spot The Violations:
    6.3A fuse with 20awg line and voltage doubler switch wires, and 2A line rectifiers
    No EMI/RFI filter- STOP CALLING IT A TRANSIENT SUPPRESSOR!!
    Shit cans for caps- primary is silkscreened for bigger cans
    Board silkscreened for bigger coupled inductor than the one present
    'ERL35' looks like an EER28
    No pi filters in the outputs
    'Diodes on a bracket' bullshit
    Free resistors/fuses for the output leads
    "6.3 A fuse, which is the case, it is a model between 230 W and 300 W" Nice try, jerk. Who the hell qualified your dumb ass to determine that?
    "12V-A & 12V-B" Think ya foolin me, asshole? Look at the back of the board and tell me where all the 12V wires terminate- on the same bus.
    As Billy Mays would say, "You shittin' me?"
    -Paul
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      l
      Solytech silkscreens it on the PCB. They say "5A Fuse for 150W-200W, 6.3A Fuse for 230W-300W" etc....
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        I don't care what the silkscreen says. Those cheapies all have the same fuse size vs output wattage ratio. Possibly, one of them had a 4 or 6A rectifier and #18 cu on the line side, way back when they got their first 'prototype' to copy.
        Don't forget that those are aluminum wires. That #20al only has the ampacity of #22cu, plus any derating for ambient temps- in this case, the inside of the PS. Insulation type also matters, but it's not gonna be more than 3A.
        In any AC line connected device, #18cu and 75 or 90 *C. Not sure if 60* is allowed anymore. This thing has no UL file number, counterfeit or otherwise.
        Just rememba, tiny wyyazz makes it cheeper.
        -Paul
        EOL it...
        • TheLaw
          • Jan 2011
          • 477
          Dear Lord....
          If you were the designer of this, would you feel bad about this when you went to sleep at night? I couldn't live with myself. What are those. 1N401s??? Woww....
          • pavithra_uk
            • Nov 2010
            • 44
            In here Sri Lanka, Most crappy sellers are selling this kind of PSUs as a hi-end PSUs
            A guy from a shop said "Its new technology design - light weight" LOL LOL LOL
            they sell these PSUs for 15 ~20 $
              master hoarder
              • May 2008
              • 12164
              I like how there are huge load resistors right next to the filter capacitors on the secondary. Even if this PSU was used in a low-power Pentium 3 computer, those resistors will likely cook the capacitors in a month, and then you'll wonder why the system doesn't boot.
              And the "Diodes on a bracket bullshit" for the 12v rail is just hilarious. 72W on the 12v rail is seriously low. I'm actually quite surprised they were able to pull so much power on the 12v rail in the above review.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                The 3A rating of the diodes isn't an absolute maximum, it's a recommended rating. If you can keep them cool, they put out more. But as you saw, they do fail if overloaded for too long.
                • Scenic
                  o.O
                  • Sep 2007
                  • 2640
                  i'll let this image speak for itself.. (discoloration)
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    That's nothing compared to what i have on some of my Deer PCBs. But still, discoloration like that on a brand new supply... fail.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Oh Deer. Oh deer. Even the TT BTX400 (which is also a deer) is better than that, although I've load tested two of them so far and both exploded when I attempted to draw 320W.
                      EDIT: http://www.youtube.com/watch?v=q41GjPgm9d8 <- the test video of one of them.
                      • Rulycat
                        • Apr 2010
                        • 724
                        What happened to Solytech being able to make an 80Plus Gold PSU? Haven't they learned anything? Perhaps the lure of Apevia's money is too much.
                        • b700029
                          Banned
                          • Sep 2010
                          • 640
                          I have a no-name AT (not ATX) PSU from the 90s that has an almost identical PCB, down to the heatsinks, except it uses a real bridge rectifier on the primary and doesn't use a diode pair for the 12V. It's rated for 250W.
                          And "Figure 13: No filtering coils in the secondary"? More like "insufficient", unless those two coils I see there aren't connected to anything.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            They mean no pi filters. To reduce ripple further a second coil-cap filter is placed after the main filter caps. It also has the effect of the thing simply going undervoltage in the event of main filter cap failure, rather than destroying the computer with huge peak voltages. The caps in the pi filter rarely (if ever) fail because they are subjected to very little ripple current. They only fail if they happen to be located next to those pesky minimum load resistors...
                            • kaboom
                              "Oh, Grouchy!"
                              • Jan 2011
                              • 2507
                              Look at how the board has holes and silkscreening for TO-247 rectifiers for 5 and 12!
                              Why not just eliminate the heatsink and use FR102s?!
                              "Innovative feature unlike any other PSU; you've heard of fanless- enter heatsinkless."
                              I played with one of these little bastards once. I loaded it with one of those 50W/12V A19 bulbs. The FOP over the spaghetti wires was maybe 1/3 a volt at 4.166A. Never mind the poor voltage regulation, even with something on 5.
                              EOL it...
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                That's so they can fit those DO-201 rectifiers for the 12v.
                                I believe FSP did this on their latest 80 plus gold PSU. Aurum 700W was it called? I think so.
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  Seasonic Xseries and FSP Aurum have very small heatsinks, they use the bottom side of the casing as a heatsink.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    The efficiency of ca 90% helps too
                                    Not like this thing which will be happy to not trip the breaker when generating 100w DC
                                    • b700029
                                      Banned
                                      • Sep 2010
                                      • 640
                                      http://rwlabs.com/images/articles/fs...um_700_013.JPG
                                      It's almost like those gutless wonders, except it can do 90% efficiency
                                      • Sus256
                                        HISENSE 65E7KQ PRO - no boot
                                        by Sus256
                                        Hi all!
                                        HISENSE 65E7KQ PRO
                                        RSAG7.820.13512 - chassis
                                        MT9618BAATAB - cpu
                                        RSAG7.820.12059 - power
                                        HD650Y3U77 - panel
                                        KLM8G1GETF - emmc
                                        Replaced emmc.
                                        Terminal log
                                        UART
                                        AC_ON
                                        E-B
                                        FDE enabled
                                        06-01-2025, 02:11 AM
                                      • dragometin
                                        Hitachi 40HYC42
                                        by dragometin
                                        TV Model: Hitachi 40HYC42
                                        Power Supply: 17IPS71
                                        MainBoard: 17MB95M
                                        Panel: VES400UNDS-2D-NO3
                                        When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                        I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                        Is there any variants on 17IPS71 power supply's?
                                        UART output pins 10 and 12 on scart connector:
                                        Code:
                                        12:24:04.595
                                        08-08-2024, 05:53 AM
                                      • Perry Babin
                                        Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                                        by Perry Babin
                                        This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                                        04-03-2024, 10:40 AM
                                      • remizbushka
                                        Dell inspirion 5775 bios "Unlock Setup fail"
                                        by remizbushka
                                        Hi sirs. please help
                                        Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                        After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                        What I did:
                                        I read the bios dump.
                                        Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                        03-24-2025, 09:07 AM
                                      • cnti
                                        Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                                        by cnti
                                        Hi.
                                        BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                                        This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                                        BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                                        RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                                        burned, measured 10M ohm.
                                        QM801 [real PSU:...
                                        10-19-2023, 05:33 PM
