AOpen FSP300-60BT(12V)
  • sulbert
    • Dec 2004
    • 59
    Has one bad cap - Jamicon TK series 3300uF 10V (all the other caps - almost all Teapos - look OK) and a burnt resistor (caused by the bad cap?).
    It was connected to a board that had bad caps (Epox 8K9A2+) and the previous owner claimed that it still was still stable - didn't try it myself, thought I will fix it at first.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: AOpen FSP300-60BT(12V)
    Jamicon TK? thats just great........any more bad news today
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      thats a fortron and the resistor is not burned.
      its shrinktube and they all look like that.
      recap and reinstall.its worth it.
      • sulbert
        • Dec 2004
        • 59
        I'm not sure it failed because of the "bad cap problem". The failed cap is connected between +5V (the red wires near the capacitor) and ground. The resistor must have been quite hot to make the shrink tube look like that, right?
        • PeteS in CA
          • Aug 2005
          • 3580
          • USA, Unsure of Planet
          Shrink-sleeving on a 5W or 10W power resistor? What's up with that? They already insulated the long wire lead. The shrink sleeving will hold in heat, which probably caused the shink sleeving to shrink even more until it split.
          PeteS in CA
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It looks like they just used a bit too much shrink tube, they only wanted it to cover the lead but it got a bit long maybe? Since it's only covering half of the resistor I mean...
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              note the screw in the inductor on the right.
              cheap iron core :-)
              • sulbert
                • Dec 2004
                • 59
                Replaced the cap with a Sanyo MV-WX series low ESR one (it's OK, isn't it?), removed the shrink tube from the resistor and the PSU is working fine again.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Excellent choice
                    by momaka
                    03-12-2025, 03:42 PM
                  • flibidy
                    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                    by flibidy
                    I have here a Magnum IA.100 which belongs to my parents.
                    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                    What Ive done........
                    01-01-2025, 01:26 PM
                    Copy DMI info easily with Hex editing software and Macro script
                    by SMDFlea
                    Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                    Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                    02-28-2023, 02:14 PM
                  • ZixuTech
                    Dell XPS 15 9570 - LA-G341P - Power cycling after liquid damage and blown ISL88738
                    by ZixuTech
                    I am dealing with this LA-G341P, which had heavy liquid damage around the Audio board, Battery charging circuit. I went and cleaned liquid areas and left the audio board disconnected.
                    It had blown PQ1900/02/3 as well as a trace on PU1900. I replaced all 4, and now it turns on and switches off. With a connected battery, it turns on and stays on for a while, even loading the system, then cuts off suddenly.
                    Charger only - without a battery, the PQ201/PD200 area gets hot. I can see the chipset and CPU also warm up for a second trying to pull up to 2A, then cust off....
                    10-22-2022, 10:33 PM
                  • b0n3v
                    [Help]Reading EC - T14 G1 AMD with RT809h
                    by b0n3v
                    Hello everyone!
                    I try to read the EC ITE/IT8300FN where the bios password is stored.
                    The laptop is Lenovo T14 G1 AMD Ryzen 4650U, the MB is NM-C801.
                    I can't read the chip with RT809H with ITE board and PFC cable. Might be I need to do something more to enable programing mode(SPI Enable?).
                    I saw the post in another forum for T14s AMD (different MB but same EC configuration and pinouts) and one user successfully read and write the the same chip with SVOD3.
                    Some details what i did:
                    Battery and CMOS battery is unplugged.
                    I click Read and then...
                    05-15-2023, 04:02 AM
