Atx psu 5Vstb present, no output
  • adelage
    • Dec 2019
    • 16
    • italy
    Hi guys,
    I am currently trying to fix an atx psu which has 5v stb present, but doesn't turn on when shorting the pson wire to ground (I have tried with and without load), the pwm/supervisor is a est7502 (which I have replaced), I have checked every diode, every transistor and every cap and they all look fine (capacity wise, I don't have an esr meter yet), the only anomaly is the second voltage (is it called bias voltage maybe?) coming out from the standby transformer, which reads 13.5v (I believe it should be above 15/16v), any suggestion on what to check next?
    • 31187
    Re: Atx psu 5Vstb present, no output
    check any opto-isolators
    • adelage
      • Dec 2019
      • 16
      • italy
      There's only one optocoupler for the 5Vstb line which works fine
      • harp
        • Jun 2022
        • 622
        • Planet Earth
        Have you few sharp images from both side, may help for suggestions
        What is the brief history of psu, suddenly dead or any past simptomps?
        How do you test optocoupler?
        What is voltege on pson green wire?
        Is you check for short anywhere on pcb board or from any output?
        • adelage
          • Dec 2019
          • 16
          • italy
          Unfortunately I am at home now so I can’t provide any pictures, will do it tomorrow.
          The psu was pretty much new, it suddenly stopped working without any particular symptom,it is a bog standard chinese model (2 big caps in series with 2 bjt), the 5v standby circuit works fine so I didn’t need to test the optocoupler and its feedback circuit (at first I tried replacing the optocoupler and the tl431 just in case, but the readings on both sides remained identical as before), the voltage on the green wire is 5.2v (before shorting it to ground to turn it on).
          I couldn’t find any short, I checked all the outputs, diodes, electrolytic caps and transistors (out of circuit) and everything seems fine. I couldn’t check with a scope, but when I try to turn it on I can read a bit of voltage on the outputs for an instant, it’s like the est7502 (which I replaced as well) ic is stopping it for some reason, I have even tried to disable the ovp and uvp shorting the first 4 pins to ground but nothing changed.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            It's not going to be the est7502 IC - those and many of the TL494 / KA7500 clones are pretty robust ICs.
            The auxiliary winding on the secondary side (from the 5VSB transformer) at 13.x Volts is OK.
            With no images and no further testing, I'd suspect these items first:
            1) Bad cap or multiple bad capacitors on the output (low capacitance / high ESR.)
            2) Bad solder joint on any of the output inductors
            3) Blown BJTs on the primary - a lot of times, one or both can blow open-circuit, along with their Base-drive resistors, so you won't see any short-circuit, but PSU simply won't work.
            4) Blown driver BJTs on secondary side (typically small TO-92 or TO-92L NPN BJTs) or bad protection diodes across their output. I had a case like this and the high resistance and relatively high voltage drop (though still a bit low for a diode... but I missed that clue), which made me go in circles several times before I caught this.
            Once we get pictures, I might be able to provide more help. Honestly, though, most of the cheap no-name half-bridge PSUs with a ton of undersized or missing components aren't really worth fixing, except for learning purposes.
            • adelage
              • Dec 2019
              • 16
              • italy
              Sorry I had a couple of busy days and couldn't reply before..
              Anyway here are some pictures of the board, as per your suggestions: all the electrolytic caps look fine (I only checked capacitance since I don't have an esr meter), I couldn't find any bad solder joints anywhere, and I checked all the bjts and the main diodes on the board and everything seems fine, now I will have a look again in case I missed something.
              Btw, I know it's not worth fixing it, but I am just studying and learning how to fix power electronics.
              Thanks for your reply.
              • harp
                • Jun 2022
                • 622
                • Planet Earth
                R14, R18 whats going on there?
                R18 150k looks like cutted and lifted but left purely soldered legs
                R14 missing...
                • adelage
                  • Dec 2019
                  • 16
                  • italy
                  R14 missing...
                  R18, believe it or not, was like this when I opened it (and the psu was bought new a few months ago), I tried to solder it but nothing changed, so I put back the way I found it, R14 was taken out to measure it when I took the picture, I am checking pretty much every single component just to find if anything is burned or shorted
                  • adelage
                    • Dec 2019
                    • 16
                    • italy
                    Just a quick update, I put back the resistor on r14, and I managed to test the frequency of the pwm output (pin 7 and 8), and I found out that the ic was actually switching, so I checked the main bjts on the hot side and one was actually giving some strange readings, so I replaced them both, and after that the ic stopped switching (same as the beginning) so I had the amazing idea to cut all the tracks (1 to 4) for the ovp protection pins and short them to ground, and turn it on without any isolation transformer nor incandescent bulb in series to limit the current…
                    You can see where this is going, not one but two amazing bangs! The second one was the fuse which literally exploded, while the first might have been one of the two bjts (which is now shorted, note that I tested them before and they seemed ok) ��! Now I am not sure if to proceed, since, even if I somehow manage to fix it, I guess that is gonna be kinda hard to understand which one was the original fault
                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                      by sam_sam_sam
                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                      I bought this from an eBay seller but unfortunately they only had one
                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                      I bought three of from them to also make battery packs with this output power limit in mind
                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                      04-23-2025, 05:50 AM
                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                      by momaka
                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                      09-19-2021, 08:44 PM
                    • CoppellTVRepair
                      Troubleshooting PFC with SPC1012T not raising output
                      by CoppellTVRepair
                      It has been a long while since I posted here to ask anything....hope you can help.
                      I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                      I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                      03-09-2025, 10:38 PM
                    • FrancescoV
                      Onkyo HT-R390 no sound output, video output ok
                      by FrancescoV
                      Good morning everyone,
                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                      The firmware reported is the following:
                      M:1.00/11107BLP
                      D:?.??/????????
                      O:1.00/11107AL
                      The DSP firmware given the question marks seems corrupt.
                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                      05-11-2025, 02:59 AM
                    • mecha1166
                      Copper corrosion? Yamaha HS8S Audio 1 output only
                      by mecha1166
                      OAUD Yamaha HS8S Audio one output only.
                      I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                      08-04-2023, 02:55 PM
