trying to fix a 6V 0.5A T1 (Transformer) AD050120T2 power supply
  • Tarot Superstars
    • Aug 2023
    • 60
    #41
    Re: trying to fix a 6V 0.5A T1 (Transformer) AD050120T2 power supply
    I took some readings with a multimeter with the adaptor plugged in.
    Voltage and temperature tests. Powered on. Insulated jacket, rubber gloves, protective goggles.
    Voltage Tests (Powered On)
    F1 = 1.5mV AC. ~ 0V DC.
    C1 = 335 V DC. 0 V AC.
    C3 = 1.3 V DC. 0 V AC.
    Temperature Tests (Powered On)
    Equipment = a digital room thermometer with insulated probe on a plastic stick.
    Everything I tested was at room temperature. I think that was weird. I expected if U1 and Q1 were working they would be above room temperature.
    I also tested the largish smd diodes (M7...Schottky) on the reverse side and the small smd capacitors and the resistors near U1. They were all room temperature.
    I tested the transformer, both inductors and the fusable resistor and they were all at room temperature.
    Any advice is appreciated.
    Should F1 have more voltage?
    Does the measurement on C3 show U1 is broken?
    • petehall347
      • Jan 2015
      • 4002
      #42
      if f1 was broke then c1 voltage would be zero .f1 is mains fuse
      oh and why has d2 a hole in it ?
      • Tarot Superstars
        • Aug 2023
        • 60
        #43
        D2. That is the light shining off it. I check and there is no hole in D2.
        Also, the hole in the board near D4 never had a component in it. It was covered with solder and appeared when I soldered near it.
        • redwire
          • Dec 2010
          • 3416
          [...] C3 = 1.3 V DC. 0 V AC.
          Yes, or C3 or the diode D8 has a problem. You said R1 is good. The IC could be hiccuping too, but it wont start unless over 15V is present.
          When working on the board, always ensure the main filter cap C1 is discharged before going in. You might have to discharge it or wait for the 335V to dissipate.
          • harp
            • Jun 2022
            • 261
            • Planet Earth
            #45
            F1 is 10R
            I think he is measure voltage across F1...?
            • R_J
              R_J
              • Jun 2012
              • 9184
              Have you checked the voltage across C2?
              • Tarot Superstars
                • Aug 2023
                • 60
                #47
                No I haven't measured C2. I didn't want to solder that many wires in one go.
                Yes, I figured that F1 possibly only operates during a short circuit, and that with only 10R the voltage across it would be low.
                R1 measures around 1.2MR rising to 2.2MR (and probably more) in circuit. Obviously there is a capacitor somewhere effecting the reading.
                R8 still seems to measure in reverse bias for a split second. I suppose I should take them out and measure them again.
                And to measure C2 also.
                If I connect a multimeter to the pulse output of the IC I should see a flicker on the meter, but can't measure the frequency with that.
                The traces have come off on one of the mains input wires and one end of F1 and the trace on the other end of F1 is moving up and down. I had to bridge the mains to F1.
                • Tarot Superstars
                  • Aug 2023
                  • 60
                  #48
                  New microscope setup (on a kitchen roll stand).
                  Note: the metal should be insulated but I haven't got around to that yet.
                  On the component on the top left, it says 688 or 68B.
                  What is that and what is the value?
                  The bottom left component.
                  What is that value and what does it mean?
                  Could someone give me some ideas where I could look to find a replacement IC please?
                  You don't have to give me an exact place to buy it, just where I need to look. Data sheet attached.
                  • Tarot Superstars
                    • Aug 2023
                    • 60
                    #49
                    I measured C2 with the power on using crocodile clips on it's wires.
                    It measures 337 Volts DC and 0 Volts AC.
                    Also, I have found that there IS an alternate path across the two wires of D8 the Schottky diode, so the split second reverse bias reading means nothing and I would have to remove it to check it properly. Also I think it is a fast recovering diode and not a Schottky diode since I think a Schottky diode should read less than 0.5V forward bias that this reads.
                    • petehall347
                      • Jan 2015
                      • 4002
                      #50
                      putting schematic here so easier to find .
                      if you do remove d8 check ohms on the ic pin 5 to pin 1 . it may take a short while waiting on c3 to charge from your meter . if it appears low ohms then remove c3 and try again .
                      • Tarot Superstars
                        • Aug 2023
                        • 60
                        #51
                        Thank you.
                        Can I do this test before removing D8 or not?
                        • petehall347
                          • Jan 2015
                          • 4002
                          #52
                          Thank you.
                          if you like then yes . just be sure its unplugged and capacitors discharged .
                          • harp
                            • Jun 2022
                            • 261
                            • Planet Earth
                            #53
                            It is 1% resistor coded with EIA-96 label, value 4990 ohm
                            Common resistor marked 393, mean 39k...
                            When check resisror in circuit, there shall be always less or equal ohm then marked, else is broken. Indeed, they can be broken and show not suspicious reading if is paralel connected with other stuff. Say 393 marked resistor, if you measure 42k across it, it is broken, but if you measure say 30k it may be ok or broken. Small signal resistor are rarely broken, and often visualy corupted (burned marking, hole, edges melted) in broken state.
                            • petehall347
                              • Jan 2015
                              • 4002
                              #54
                              are you sure ? i make it 680 ohms . the B meaning add a zero after 68 .
                              • Tarot Superstars
                                • Aug 2023
                                • 60
                                #55
                                I have just realized that the mosfet might still be broken.
                                I was following a theory that I had learned, that if I tested the mosfet in diode mode for junctions BE and BC and they tested fine, then if I reversed the polarity of the probes and found no junction (no voltage drop) that the transistor would be good. Also that if BC was higher than BE then it's likely to be ok.
                                I did not use any theory about Gate, Drain and source but I assume the test is the same for a transistor switch and a mosfet.
                                But for clarity, I would be testing the equivalent of BCE:
                                Base is the Gate,
                                Collector is the Drain,
                                Emitter is the Source.
                                So I would be looking for GS ~ 0.5V, CS ~0.51 V or more, and nothing in reverse.
                                But, I just checked a pre-amp transistor that from a radio that I made, and I know it was broken. I know because I put 5V in a 3V radio and it stopped working. Then there was the smell of burning and that transistor was hot. When I changed it and lowered the voltage back to 3V the radio worked.
                                I kept the broken transistor for reference. It's a BC550C (PNP).
                                I just tested it using the theory above and it tested BE ~0.59 V and BC ~0.58V. I checked the data sheet and BE is supposed to be higher than BC in this instance.
                                When I reversed the polarity I did not find a junction and it measured fine.
                                Note that my multimeter might have more of an effect on readings than more expensive ones.
                                This means there is an error in this theory since I know the transistor was broken and yet it has the same readings as a BC550C that I know is not broken.
                                So, then the mosfet could still be broken even though no reverse junctions were found in circuit tests. And even though it was at room temperature.
                                However, a mosfet works differently from a pre-amp transistor. Perhaps someone with more knowledge than me could shed some light on this. Perhaps the test works for mosfets and transistor switches but not transistor amplifiers?
                                Anyone know any good tests to verify if this mosfet is broken or not, perhaps with power on?
                                How do I find out if it's the mosfet, IC or both that are broken?
                                • petehall347
                                  • Jan 2015
                                  • 4002
                                  #56
                                  mosfets generally have gate source and drain and dont test same as transistors. another thing is when such things go bad they short out and occasionally go open circuit .i first check for shorted junctions then if all good check live voltages . this may reveal whats going on a little .
                                  • Tarot Superstars
                                    • Aug 2023
                                    • 60
                                    #57
                                    Tested no shorts in circuit.
                                    • Tarot Superstars
                                      • Aug 2023
                                      • 60
                                      #58
                                      I found this and it seems to match the IC in the data sheet provided by Lotas.
                                      However, it has 6 wires and not 5 wires like mine.
                                      https://www.alibaba.com/product-deta...437418653.html
                                      What do you think?
                                      • harp
                                        • Jun 2022
                                        • 261
                                        • Planet Earth
                                        #59
                                        I add EIA-96 atachment previously, according to it, marking code = (decoded)value * alfabet letter multiplier, so, 68 is 499, B is 10, together make 4990 value.
                                        When you see letter on the end, you must decode whole entry.
                                        • Tarot Superstars
                                          • Aug 2023
                                          • 60
                                          #60
                                          Hi.
                                          That resistor seems to read ~68 ohms. Not sure what the B is for.
                                          I performed some more tests designed to test if U1 is receiving power between the positive rail and wire 1 ground, and to test if U1 is sending out a pulsed signal from the gate.
                                          Note: I connected the multimeter probes without any polarity checking so it would be the poles are the wrong way around. The connections were so small, I didn't have time to waste switching them around...
                                          Test 1 to test if there is any power going to U1 from the positive rail to U1 wire 1 (ground)
                                          PWM power U1 Ground to the far side of R1 (which is and SMD marked 245 (24,000,00 = 2.4MR).
                                          Result
                                          335 V DC,
                                          0V AC.
                                          Test 2. Test to see if there is any pulsed signal from U1 gate (ground)
                                          U1 ground (wire 1) to multimeter probe 1 and U1 gate (wire 2) to multimeter probe 2.
                                          Result
                                          Flashing multimeter reading (changing from one value to another).
                                          From 0.4V DC to -0.1V DC,
                                          AC -0.4V AC (maybe a false or insignificant reading).
                                          Conclusions and Discussion
                                          I assume there is power going through U1. 335 V DC is quite a lot.
                                          I assume that U1 IS sending out a pulsed signal. I am not sure and would assume that if the rest of the circuitry was working fine this would result in some output voltage. Not sure if the frequency or width of the pulses high or long enough.
                                          Either the pulses are incorrect, or the signals aren't effecting Q1 as they are suppposed to, or some other circuitry from Q1 to the output is broken.
                                          I am not sure if 0.4V DC pulse from U1to the gate of Q1 is enough to switch it on.
                                          So, I am wondering if anyone knows what these readings mean.
                                          What sort of tests might help to figure out what is broken and what isn't.
                                          It's possible I missed some instructions already given. If so, I don't mind if you repeat yourself.
