Unfortunately I got rid of most of my power supplies a few years back so I hunted some on eBay. Of course I could have got some with already good caps but what's the fun in that when you can save unsuspecting victims on eBay from buying something that could cause them problems?
I'm also aware that Solytech is capable of making a decent unit, minus their caps. This one is on the 80 Plus website as being able to do its full wattage.
I bought two of these as a lot. One was made in July 2017 and one was made in September 2017. Interestingly, the only difference between the two was the primary cap.
The July 2017 had a 220µF 450V DeXon cap (no series) rated at 85C. I was surprised to pull it and see that it read 209µF and 0.22Ω ESR. (I decided to give Wurth caps a try)
The September one had a taller 220µF 450V ChengX LS cap rated at 105C. I found this very interesting because the DeXon 85C cap is bulged! As you can see there, and I am not able to press the disc down.
I was intrigued by this because I tested both of them with a paperclip and both turned on. Curious, I hooked them up one at a time to my Kill-A-Watt brick. I tested the one with the ChengX cap, it powered on and idled at a shocking read of 0W with a PF of 02.
Due to there being no minimum load resistors, the voltages were all out of whack.
12V = 12.83V
5V = 4.72V
3.3V = 3.38V
5VSB = 5.18V
-12V = -10.17V
I hooked up the one with the bulged DeXon cap, and this one read 10W draw with just a paperclip and a PF of 59. All of the rails read exactly the same as the healthy one except the 5VSB was 5.17V
So what's the deal with 10W more? Is it because the cap may be in "early" stage of failure? Is the leakage current increasing, causing the PSU to have to charge it more with the mains? I'm very curious about this since it didn't have an affect on the secondary at all (with no load at least).
Other shots:
The primary uses:
(For PFC):
x2 Toshiba TK10A60D (10A) FETs
Diodes Incorporated LTTH806RW (8A) power diode
(Switchers):
x2 Toshiba TK13A60D (13A)
Secondary:
3.3V: x1 Vishay 30V30CT (30A)
5V: x1 Vishay 30V45CT (30A)
12V: x2 Vishay 20V60CT (20A)
It looks like this PSU does actually have two 12V rails. (Pleas correct me if I'm wrong!) One of the rectifiers is just jumpered over to the other one where they both pass through the same winding on the big toroid. Then, they are jumpered to their own sections of 12V wiring but where they are jumpered from is the same pad. I'm used to seeing a giant shunt, instead it just uses two small jumpers (and a giant glob of solder lol)
In my next coming post I will show the recap and my intentions with this PSU!
Another note, what's up with this not having a current inrush limiter?? Could that have caused the main cap to bulge? Although it does have one MOV by the fuse. Should I add an NTC? I have one from a dead half bridge Solytech.
12V = 12.83V
5V = 4.72V
3.3V = 3.38V
5VSB = 5.18V
-12V = -10.17V
Other shots:
The primary uses:
(For PFC):
(Switchers):
Secondary:
