Can High Side damage on an SMPS get across the Transformer to the Low Side?
  • Briesmith
    • Apr 2022
    • 15
    • United Kingdom
    I have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
    As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on the standoffs at the time the amp blew up.
    If anyone has any comments on how far any damage is likely to have spread, I would be grateful.
    • 31083
    Re: Can High Side damage on an SMPS get across the Transformer to the Low Side?
    looks like the mosfet shorted and took out the resistors.
    maybe because of a bad cap.
    secondary is probably fine, but thats a complex looking board.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      >>> Can High Side damage on an SMPS get across the Transformer to the Low Side? <<<
      It depends on the SMPS type and topology... but generally, it's a very rare occurrence and typically may only happen if the PWM IC gets "stuck" in some way so as to ramp up the PWM to a much higher value than it should be, causing an OV condition on the secondary. But again, that's almost never the failure mode. The transformer itself does provide some limitation on how much power a "strong" PWM pulse can carry onto the secondary side, which in essence provides protection to the secondary side.
      Looks like an SMPS with a class D amp all combined on one board.
      The SMPS looks like a double-forward topology.
      I agree about checking the small caps near the big one on the primary (that is now removed), since those looks like they are cheap brands.
      Could also be that the clearance / distance between the primary cap's leads and the aluminum heatsink just wasn't big enough, so perhaps the HV arced over to secondary side ground. But then that doesn't explain why those resistors would blow. Those resistors are for current sense on the primary side (for the MOSFETs), so indeed one or both MOSFETs could be blown up... or their damper diodes.
      • Gentian
        • Mar 2023
        • 12
        • Albania
        I also agree that the 2 mosfets connected to those resistors are blown and no damage on the secondary side of the transformer. I would suggest checking the Greatz bridge (AC/DC) converter before the big capacitor on the ac side because it can be the reason for the big capacitor failure. You can replace it also it may looks good with a new one to be sure no problem on the ac side.
        Good luck!
        • Briesmith
          • Apr 2022
          • 15
          • United Kingdom
          Thanks everyone for replying. I'll let you know how I get on.
          • Briesmith
            • Apr 2022
            • 15
            • United Kingdom
            Update: I removed the 25F60CPM MOSFET and it tests as a resistor so it's definitely defective. Is the advice still to remove the other MOSFET or can I leave it where it is?
            • CapLeaker
              Leaking Member
              • 8210
              Remove it and test it.
              • Briesmith
                • Apr 2022
                • 15
                • United Kingdom
                Thank you CapLeaker and everybody else who has helped with this. I'll remove the other MOSFET and report what I find.
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
                • ohren
                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                  by ohren
                  Hello!
                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                  Measured voltages with no load:
                  After rectifier diodes
                  12V: 6.17 V
                  5V: 5.67 V
                  Secondary transformer pins AC measurement (really don't know if this says anything)
                  12V: 2-2.5 V
                  5V: 1.04 V
                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                  03-18-2023, 10:33 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • flibidy
                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                  by flibidy
                  I have here a Magnum IA.100 which belongs to my parents.
                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                  What Ive done........
                  01-01-2025, 01:26 PM
                  Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                  by momaka
                  This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                  Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                  Macron Power Technology Co. LTD.
                  Let’s look at the PSU itself.
                  The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                  06-02-2021, 10:05 PM
