FX505GT MB REV 2.0A Schematic or Boardview
    No photos found.
  • mard312
    Legion Go 8APU1 boardview or schematic
    by mard312
    I’m working on repairing a Lenovo Legion Go that suffered liquid damage. Unfortunately, one of the ICs on the motherboard burned out, and I haven’t been able to find any boardview or schematic for this model anywhere.
    Does anyone happen to know what this particular chip is, or have access to the schematic/boardview for this motherboard? Any help or reference would be greatly appreciated.
    Today, 01:01 PM
  • AustinCER
    In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
    by AustinCER
    I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
    No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
    There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
    Any insight, schematic or boardview would be greatly appreciated.
    Model: Lenovo Ideapad Flex 5 14ALC7...
    11-04-2025, 03:49 PM
  • PacoGT
    HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
    by PacoGT
    hello firends
    i search the schematic or boardview
    I have this motherboard, but I can't find the schematic or the boardview.
    The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
    So the computer doesn't turn on, and the 3V disappears after a few seconds.
    The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
    The new problem arose after removing the bad chip.
    3V and 5V remained together,...
    08-19-2025, 08:25 PM
  • hosain0489
    Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
    by hosain0489
    I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
    Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
    If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
    Thank you very much in advance!
    07-15-2025, 11:20 AM
  • re-atari
    Gigabyte GA-H110-D3A schematic/boardview needed
    by re-atari
    Hello all,
    Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
    This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
    02-24-2025, 06:45 PM
