Acer SP513-51 Drift_SKL 16801-1M Help finding what component it is.
  • haxatto
    • Oct 2020
    • chile
    Hello i need the schematic or boardview for Drift_SKL 16801-1M, these is my laptop and have a restart problem, show the led indicator of on while 5 or 10 seconds and then go to off, these happening always and dont start, so for fix it i need the shcematic or boardview. thx for all
  • Bartoloni
    • Jul 2018
    • 140
    • Italy
    Probably is some kind of HALL sensor (double?)
    4 legs, one to ground, one 3.3V .. the other 2 have no voltage.
    the laptop is an Acer Spin SP513-51 (no schematics available)
    the issue is that the laptop is coming-on only flecting the board (a broken USB port "curved" the board)
    and when releasing the board , the screen become totally black (video cable is ok) like some sort of black-mode when lid is closed.. but laptop continue working without backlight.
    now i'm thinking that 1 signal that need to be send to HALL (the 4th leg?) is missing (broken trace inside board?) .. some sort of ENABLE signal?
    and the HALL sensor is not pushing 3.3V to another leg, can't find any datasheet similar to this SMD... asking help if someone know this can of sensors..
    thank you!
    on diode-mode i have .5V on the 2 legs that i need to identify.
    Last edited by SMDFlea; 11-01-2021, 06:31 AM. Reason: Acer SP513-51 Drift_SKL 16801-1M
    • rielfreak
      • Jul 2017
      • 23
      • Philippines
      Re: Help finding what component it is.
      no response on one of the pins when you put magnet on top of it?
        • 22199
        Re: Acer SP513-51 Help finding what component it is.
        Originally posted by Bartoloni
        the lapètop is an Acer Spin SP513-51 (no schematics available)
        And the motherboard part number is ?
        • Bartoloni
          • Jul 2018
          • 140
          • Italy
          HI SMDflea.. thera are 2 different boards for this model (2 diffierent names for what i know..but the one i have is Drift_SKL 16801-1M)
          and the component is between USB 3.0 and USB 2.0 ports
          no differences with magnet and without (at first i supposed this was not an HALL sensor at all... but i checked on the neodinium position and the only component that i can suppose is a sensor is this..)
          there is also another board schematics request on teh forum:
          https://www.badcaps.net/forum/showthread.php?t=89293
            • 22199
            Re: Acer SP513-51 Drift_SKL 16801-1M Help finding what component it is.
            The schematic and boardview are available at some paid sites,can`t find it on any free sites.Hopefully someone will post it .
            • lazrdo
              Electronic Love
              • Oct 2019
              • 29
              • Egypt
              May be this schematic helps you
              Acer Spin 5 SP513-52 Wistron Woody WL 18734-1M Slinky WL 18753-1M
              • lazrdo
                Electronic Love
                • Oct 2019
                • 29
                • Egypt
                And i think it is a LDO (Low Drop Voltage Reg) if i am not wrong
                • Bartoloni
                  • Jul 2018
                  • 140
                  • Italy
                  thank you Lazrdo... i also have this scheme... but looking at the sensor is on a secondary board (with audio jack and USB) in this model i have a second card but without any sensor, just buttons, led and a card reader... i saw LID_CLOSE and LID_CLOSE2 (2 signals) but i can't understand from where they are coming. on the scheme you provided there is something similar to a LDO used in the USB area?
                  [edit]i looked to (i think) every schematic about ACER SPIN series ... and there is one that is the
                  Acer spin 1 sp111-34n that have a 5 legs hall sensor... called BU52013HFV... that looking at datasheet uses the "G" letter to identify GROUND... and H to identify output (in this cas my H is 3.3V )
                  • lazrdo
                    Electronic Love
                    • Oct 2019
                    • 29
                    • Egypt
                    Look page 66/106 on the schematic (SSID = User.Interface)
                    • Bartoloni
                      • Jul 2018
                      • 140
                      • Italy
                      AZC099-04S is a Low Capacitance ESD Protection Array
                      and the G517F1T12U is a some sort of Power Distribution Switch
                      • Bartoloni
                        • Jul 2018
                        • 140
                        • Italy
                        OK.. the SMD is HGDEDM013A .. that is a dual hall sensor...
                        • Bartoloni
                          • Jul 2018
                          • 140
                          • Italy
                          Re: Drift_SKL 16801-1M (acer spin 5 sp513-51) schematic or boardview
                          Maybe this can help
                          • mon2
                            • Dec 2019
                            • 14766
                            Posting 2 x boardview files that may be of help for this logic board.
                            • joen_d66
                              • Apr 2013
                              • 72
                              • jakarta
                              thanks a lot bro,this help me
