HP-Envy15 15-as133cl schematics and BV request
  • kroman
    • Aug 2021
    • 8
    Hello, I am looking for schematics or board view for HP-Envy15 15-as133cl, Board: Vanilla1-6050a2857201-mb-a01
    Fans spin but no POST, no image out from hdmi or known good display. cmos battery is good, tried clearing cmos, tried known good ram in both slots alternating, tried multiple key booting combinations, draining all power, booting with known good battery and known good chargers combined and independently.
    Friend says she left it on her desk watching youtube shows to bed, woke up with laptop not turning on.
    history: battery replaced once, one ram stick was removed before when it became bad, came in twice with no booting which at the time issue was fixed with clearing cmos.
    I have used search features here and in google and I haven't found exact schematics, one example is "HP Envy 15 (Quanta SP7).pdf" can be found on google but not sure if thats the one I need.
    Any help with those files would be greatly appreciated!
    Should be worth noting: i have the ssd with me and I can boot it on another PC and I can get windows event log files of right before it died
  • ronaldopdias
    • Jul 2015
    • 93
    • United Kingdon
    Re: HP-Envy15 15-as133cl schematics and BV request
    Hi. Good afternoon.
    I have the same laptop on my desk with the same issue reported by you.
    I've tried all the options that you mentioned above.
    The only difference is that when it came in CPU had no voltage and fan on high speed.
    After replacing RAM the CPU started to get voltage and the fan went to low speed, but still no display.
    Have you fixed the issue with your laptop?
    • kroman
      • Aug 2021
      • 8
      Originally posted by ronaldopdias
      Hi. Good afternoon.
      Hello, No I have not fixed the issue I still have the board with me. No obvious shorts heating up.
      I put it aside for now but I can take voltage readings if you would like to compare with.
      • steven reynolds
        • Mar 2024
        • 8
        • san jose
        Hi, I know the post is old but these boards give a problem in the integrated circuits intersil 95859 you test voltage outputs in CPU coils
        • jake-b
          dell e6540 boots to black screen (no dell logo)
          by jake-b
          good morning all,
          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
          01-08-2024, 10:29 AM
        • irepair559
          Ps4 1215a hdmi diode readings good everything good but no pic??
          by irepair559
          PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
          01-05-2023, 12:32 AM
        • ResoluteHawk
          Alienware 17 R3 (LA-C912P) Powers on then powers off after 4-6 seconds
          by ResoluteHawk
          I have an Alienware 17 R3 (board is a C912P) that I recently starting trying to repair. Originally the issue was the charger going into protection mode when plugged in to the laptop. I found a short on the motherboard (one of the capacitors on the back of the board under the DRMOSes for the CPU) and the charger when plugged in now doesn't go into protection mode anymore. The laptop powers on, the lights on the keyboard, alien head, and alienware logo light up, and the fans spin. The issues are:
          1) The battery doesn't charge. I've probed the charger jack and it's only receiving 0.633v...
          06-17-2022, 01:04 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • GIGA10
          Gigabyte G5 KE Clearing CMOS won't reset BIOS Admin password
          by GIGA10
          Hello everyone. I'm not sure if this post belongs in this section? If not, please kindly move it to right section Mod/Admin.
          I have a Gigabyte G5 KE laptop and I have forgotten the BIOS Admin password. I can enter BIOS menu but when trying to enter BIOS settings it ask for my password which I have forgotten. I can boot also in to Windows 11. I have tried to clearing CMOS by removing the CMOS battery for 10h. I have tried also to remove both power battery and CMOS battery and bridge the CMOS 2 pin connector on the motherboard. Then when booting I get a message that NVRAM has been...
          12-23-2022, 03:31 AM
