Schematics/boardview iPad Air 2 820-4550
  • mferna14
    • Jun 2018
    • 1038
    Does anyone have & are willing to share the Schematics/boardview iPad Air 2 820-4550... The problem is, its not charging the battery, other than this all works fine. I replaced the IC 1601A1 the charging chip, still the same, I do get the 5V from the charging cable on the test points. Any other tips wll be greatly appreciated. Thanks in advance
  • du_dung
    • Sep 2019
    • 4
    • philippines
    Re: Schematics/boardview iPad Air 2 820-4550
    here you go.
    • mferna14
      • Jun 2018
      • 1038
      Thank you sooooo very much.. really appreicate du_dung... once again thank you
      • vgcrepairs
        • Apr 2020
        • 5
        file doesn't work, says RAR failed - File is password protected
        • mon2
          • Dec 2019
          • 14505
          I think your WINRAR is too old. Try the attached.
          • hpibmx
            • Jan 2021
            • 7
            • Malaysia
            Originally posted by du_dung
            here you go.
            Thank you so much
            • Karmet
              • Dec 2022
              • 8
              Greetings! Does anyone have the ".brd" file? Thanks for the help!
              • joen_d66
                • Apr 2013
                • 66
                • jakarta
                here you go.
                thanks ya bro
                • Spark29A
                  • 3
                  I need the part number / information for this part.
                  It does not seem to be listed on the board view. Can anyone help me ?
                  Thanks,
                  Spark29A
                  • AL._.EX
                    • Dec 2022
                    • 888
                    • Belarus
                    Possible R4010 - R4013...
                    • Spark29A
                      • 3
                      Thanks, it is R4011 if anyone ever face the same issue.
                      Quite small to replace but after changing a few parts, the IPad works like a new!
                      • quezon
                        • Dec 2015
                        • 70
                        • Philippines
                        thanks
                        • GeirAndersen
                          iPad .pcb file collection
                          by GeirAndersen
                          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                          IPAD COLLECTION 1
                          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                          12-09-2024, 09:28 AM
                        • a_p3rson
                          Apple Watch Charging Controller Schematics / Boardview - 820-02601
                          by a_p3rson
                          Hi there,
                          I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                          You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                          This daughterboard uses an interesting...
                          04-21-2025, 11:41 PM
                        • unimatrix93
                          Ipad Pro 3rd Gen. 11" (A2459) boardview/schematics needed
                          by unimatrix93
                          I replaced the screen on my iPad and since then the battery indicator shows 0%, although it taking charge according to my amp meter....
                          06-23-2025, 01:26 AM
                        • CG_Dionysos
                          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                          by CG_Dionysos
                          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                          • Model: A1707
                          • 15-inch, Mid 2017
                          • 3.1 GHz Core i7
                          • 16 GB RAM
                          • Radeon Pro 560
                          • 1 TB SSD
                          • Board number: 820-00928-A
                          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                          Thanks in advance!
                          Greetings from Germany...
                          Yesterday, 06:43 AM
                        • Tribalus43
                          Lenovo Thinkpad T14 gen 2 intel schematics/boardview
                          by Tribalus43
                          Request: Lenovo ThinkPad T14 Gen 2 (Intel) Schematics/Boardview
                          I’m looking for the schematics or boardview for a Lenovo ThinkPad T14 Gen 2 (Intel) with the following board:
                          HT4B07HP4B0 / HT5B1 / HP5B1 / HT4B2 NM-D352 Rev: 2.0
                          I’m currently dealing with some startup issues and would like to test for shorts. Any help would be greatly appreciated.
                          Thanks!
                          09-01-2025, 12:10 PM
