plz boardview from bic50 rev 2.0
  • ikahmed
    • Sep 2015
    • afriquia
    • 22035
    Re: plz boardview from bic50 rev 2.0
    Schematic + Boardview
    • chemseddine
      • Jul 2017
      • 34
      • algeria
      thankssssssssssssss
      • ABDO26
        • Jul 2019
        • 14
        • medea
        thankssssssssssssss
        • HABIBOU11
          • Jul 2015
          • 50
          • ALGERIA
          thanks
          Хвала Аллаху, Господу миров
          • mavaramat
            • Jan 2014
            • 12
            • Iran
            Tnx very much
            • _F.fernan
              • Dec 2014
              • 78
              • Philippines
              thanks a lot
              • msa i
                • Nov 2020
                • 5
                • Russia
                thanks
                • Zeelie
                  • Jun 2021
                  • South Africa
                  Thank you
                  • oflayan
                    • Dec 2020
                    • Italia
                    Thank you
                    • NADJIB
                      • Jan 2017
                      • 20
                      • ALGIRIA
                      Thank you
                      • simsot
                        • Jul 2017
                        • 8
                        • Kazakhstan
                        Thank you
                        • kaby06
                          • Jun 2019
                          • algerie
                          thanksssss
                          • Noreddin
                            • Jan 2020
                            • 73
                            • mostaganem
                            Thank you
                            • mido23
                              • Feb 2018
                              • 13
                              • paris
                              Thank you
                              • miloud
                                • Nov 2021
                                • 15
                                • algérie
                                Thank you
                                • kdm71
                                  • Jun 2023
                                  • Abudabi
                                  Thank you
                                  • Bimad99
                                    • Jun 2023
                                    • 37
                                    • Algeria
                                    What app are you using ??! Didn't work on BoardViewer app
                                    • abbassink
                                      • Aug 2015
                                      • 83
                                      • iran
                                      Thank you​ BRO
                                      • NADJIB
                                        • Jan 2017
                                        • 20
                                        • ALGIRIA
                                        Thank you
                                        • AustinCER
                                          In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
                                          by AustinCER
                                          I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
                                          No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
                                          There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
                                          Any insight, schematic or boardview would be greatly appreciated.
                                          Model: Lenovo Ideapad Flex 5 14ALC7...
                                          11-04-2025, 03:49 PM
                                        • PacoGT
                                          HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                                          by PacoGT
                                          hello firends
                                          i search the schematic or boardview
                                          I have this motherboard, but I can't find the schematic or the boardview.
                                          The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                                          So the computer doesn't turn on, and the 3V disappears after a few seconds.
                                          The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                                          The new problem arose after removing the bad chip.
                                          3V and 5V remained together,...
                                          08-19-2025, 08:25 PM
                                        • hosain0489
                                          Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                                          by hosain0489
                                          I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                                          Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                                          If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                                          Thank you very much in advance!
                                          07-15-2025, 11:20 AM
                                        • re-atari
                                          Gigabyte GA-H110-D3A schematic/boardview needed
                                          by re-atari
                                          Hello all,
                                          Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                          This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                          02-24-2025, 06:45 PM
                                        • jonyhdtv
                                          HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                                          by jonyhdtv
                                          Looking for schematic and boardview
                                          Model: HP ProBook X360 11 G3 EE
                                          Serial: SCG9114JG7
                                          Motherboard: L43774-601
                                          defect: touchscreen doesn't work (touch works on another computer)
                                          thanks to all​
                                          01-29-2025, 08:16 AM
