Dell Vegas/Turis SKL/KBL 15341-1/91N85 schematics
Re: dell 15 3567 schematic need
here it is
Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell Vegas/Turis SKL/KBL 15341-1/91N85 schematics
I have a MB Dell Vegas/Turis SKL/KBL 15341-1/91N85
Which was burned a charging IC (ISL88739) and condition was battery is not detected with 100k (PR4454) burned resistance. Then I change burned both charging IC and resistance. Finally It's not turned ON. I tried again burned charging IC, it's turn ON and battery is not detected again. The changed IC is OK. Could you give me any solution ASAP.
Thank you.Comment
now it's avaible
by RofixHi everyone, I wanted to kindly ask you for help, I have a problem with my Dell vegas/turis mlk kbl-r 17841-1 wx2rr PC, it turned off and I was no longer able to turn it back on, I'm checking the various voltages, unfortunately I found the 19 v up to the input components PU4411, PQ4401, thank you all for any advice
by axus009Hello friends, I have this laptop with a black screen, when turning on the fan turns and turns off after 15 seconds, if I remove the ram memory if there is a ram error code, but when extracting the .bin file from the original eeprom and want write a new one it shows verification error, it is not completely erased, this makes me think that the eeprom is damaged, I already changed the eeprom and wrote successfully, I used the bios dump from the following thread: https://www.badcaps.net/forum/showthread.php?t=95250 but it gives the same failure, if anyone can check my original .bin file, the laptop...
Channel: BIOS Requests ONLY!
by lapfixHello my friend.
When connected to power supply consumption is 0.09 amp / power button = reach 0.150 amp...than off.
i follow the power up sequence and as i know :
After getting ALL_SYS_PWRGD, the io generate a signal adressed to VRM called VR_ON / VR_EN , this is the VRM enable signal .
If CPU core is ok the VRM chip will generate its power good signal adressed to SP/PCH , this signal is termed = VRM_Power good / VR_RDY .
With this motherboard all is ok until sequence 8a= VR_RDY.
Questions :
1 =... -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Techtigeri got this Mob need help Veteran's 15341-1/91N85 no liquid damage or corrosion , bord power up but no Video PL4801 VCCGT missing ,no beep or blink code's
Flash BIOS with SMDFlea one but not the EC
(https://www.badcaps.net/forum/showth...hlight=15341-1)
POST#3 and one from
(https://www.laboneinside.com/tag/153...1n85-bios-bin/)
now the Mob shut down after 2 mins fan on full speed blink code Amber 2 white 7 power lab 0.50 drops to 0.30 Num Lock comes after 1mins DRAMRST 1.2V ALL SYS PWERGD 3.3V PLTRST ok
... - Loading...
