Does anyone have this please?
820-2936-A boardview & schematic please
Tags: None
Re: 820-2936-A boardview & schematic please
hereit is mateto open boardview , use openboardview (you can find here on the forum )
Attached Files -
The schematic is the other file in that zip and it's a pdf. Use Foxit or Sumatra to view. Or Adobe reader if you must, but big and bloated and shite just for reading PDFs.Comment
Then i unplugged the cable after a few minutes to reassemble, but before i did i plugged the charger back in, and nothing, no green nor orange. I get no power rails present from the charger, only the battery. I had 3.4v at the input pin1 on U6901 and none on the output pin2. I disconnected the battery and put a jump between pin 1 and 2 to redirect the 3.4v the way it should if it was functional incase the data lines weren't present. still nothing... i have changed the DC in board and still no light on charger.
safe to assume the magsafe charger is faulty??
Any help would be fantastic! ThanksComment
Hi folks, can anyone tell me if there's any difference between 820-2936-A and 820-2936-B?Comment
"turned out that my logic board number is 820-2936-b, encripted on logic board itself while the number 820-2565-A is written on dc in board"Comment
Did you find out if there was a difference? I'm working on 2936-b now and have a backlight issue. Pin 2 on the LCD connector burnt and I pulled it out. I need to replace L9004 as it also burnt on the board.Comment
by PacoGThello firends
i search the schematic or boardview
I have this motherboard, but I can't find the schematic or the boardview.
The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
So the computer doesn't turn on, and the 3V disappears after a few seconds.
The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
The new problem arose after removing the bad chip.
3V and 5V remained together,...-
08-19-2025, 08:25 PM -
by hosain0489Hello everyone,
I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
Thank you very much in advance!
by re-atariHello all,
Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
by jonyhdtvHP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
Looking for schematic and boardview
Model: HP ProBook X360 11 G3 EE
Serial: SCG9114JG7
Motherboard: L43774-601
defect: touchscreen doesn't work (touch works on another computer)
thanks to all-
by jonyhdtvHP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
Model: HP ProBook X360 11 G5 EE
Serial: SCG0164QLH
Motherboard: L83950-601
defect: no POWER
thanks to all-
01-29-2025, 08:11 AM -
- Loading...
