Lenovo B540 and B450 LA14 DIS MB 48.4DM04.01.1
Lenovo B540 and B450 Board No. LA14 DIS MB 48.4DM04.01.1
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ravi_1617Hello !
Model Lenovo B540
Board Details 09244-1
LA14 DIS MB
48.4DMO4.01.1
This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
when connected CMOS dont start.
3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
One more thing i want to mention ( by mistake i started at... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by Habble7Hello everyone,
I'm trying to repair the power supply board from a Lenovo ThinkVision P40w-20 monitor. The board is labeled with the following markings:
- Main PCB code: ILPI-422 VA (dated 2021/11/24)
The monitor is completely dead, no power LED or backlight. Upon inspection, I found a few components that appear damaged, particularly some resistors that are burned and unreadable.
Attached is a high-resolution photo of the power supply board.
Does anyone have a schematic, boardview, or similar power supply that can help identify the... - Loading...
