HP Spectre x360 LA-M789P mainboard schematic and/or boardview
  • leawell
    • Apr 2020
    • United Kingdom
    Does anyone have a schematic or boardview for this board, please?
  • ofluffy
    • Aug 2025
    • 11
    • US
    Hello, still missing the board view. Can't seem to find one anywhere...
    • AJ847.63e
      HP Spectre x360 - 13-4005tu DA0Y0DMBAF0 . REV: F..boardview & schematic
      by AJ847.63e
      Hey All,
      Just wanted to see if anyone has the above correct schematic and BV for this model. It seems like there are different variations with the exact same board label and revision as I've found BVRs labeled " DA0Y0DMBAF0 Rev F" which is the board label on the board I have here, but it does not match the board. The board I have has a large MLCC on it (where PR96 is) and when I continuity check it to the lines matching the BVR it does not go to where the BVR says it does, and the BVR lists it as PR96 when it is clearly a MLCC. I thought the revisions maybe mixed up in the...
      10-16-2024, 09:23 PM
    • jonyhdtv
      HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
      by jonyhdtv
      Looking for schematic and boardview
      Model: HP ProBook X360 11 G3 EE
      Serial: SCG9114JG7
      Motherboard: L43774-601
      defect: touchscreen doesn't work (touch works on another computer)
      thanks to all​
      01-29-2025, 08:16 AM
    • jonyhdtv
      HP ProBook X360 11 G5 ee schematic and boardview thanks
      by jonyhdtv
      HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
      Model: HP ProBook X360 11 G5 EE
      Serial: SCG0164QLH
      Motherboard: L83950-601
      defect: no POWER
      thanks to all​
      01-29-2025, 08:11 AM
    • PacoGT
      HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
      by PacoGT
      hello firends
      i search the schematic or boardview
      I have this motherboard, but I can't find the schematic or the boardview.
      The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
      So the computer doesn't turn on, and the 3V disappears after a few seconds.
      The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
      The new problem arose after removing the bad chip.
      3V and 5V remained together,...
      08-19-2025, 08:25 PM
    • saveandrey
      HP Envy X360 convertible, model: 15-eu0022ur boardview or schematic
      by saveandrey
      Hello!
      Could someone please help me with boardview or schematic for notebook HP Envy X360 convertible, model: 15-eu0022ur.
      I have attached a picture with de motherboard to see all specifications.
      Thank you
      06-21-2025, 10:29 PM
