ASUS ROG G513R Schematic + Boardview Needed
  • Pierro208
    • Dec 2023
    • 84
    • France
    Hi All,
    I have a Asus ROG G513R, no image on the screen, but works perfectly in HDMI, I found on the site boardviews but all are different at the EDP connector
    REF MOTHERBOARD : G513R-MP-VGT 6050A3348803-MB-A02
    Need the Scehematic and Boardview
  • gigaprice
    • Aug 2014
    • UA
    Look, it should be
    • Pierro208
      • Dec 2023
      • 84
      • France
      Thank you very much, I will look at that šŸ‘ šŸ‘ šŸ‘
      • rollogollo
        • Mar 2024
        Originally posted by Pierro208
        Hi All,
        hello,
        I have the same problem.
        Did you find the error?
        Greetings Heiko​
        • Pierro208
          • Dec 2023
          • 84
          • France
          Hello, yes the problem is solved, for my part it's the EDP connector that managed I don't know how to cut tracks, I redid the tracks and it works again
          • rollogollo
            • Mar 2024
            Thanks for the feedback
            best regards
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3682
              • slovakia
              • hard-enduro
              Originally posted by gigaprice
              Look, it should be
              cannot download it. any hint why?
                • 23614
                It`s due to some recent server problems. The files will need reposting.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3682
                  • slovakia
                  • hard-enduro
                  Hi All,
                  I have same symptoms. did u find fault?
                  • amsalingam
                    • Nov 2016
                    • india
                    ASUS ROG G513R Schematic + Boardview Needed G513R-MP-VGT 6050A3348803-MB-A02
                    • someonenotyou
                      • Feb 2021
                      • 65
                      • LV
                      Hi.
                      Anyone got boardview and schematics for:
                      G513R-MV-VENDOR
                      6050a3348806-MB-A01
                      Thank you.
                      • pooya_pm
                        • Jan 2021
                        • 266
                        • iraq
                        Invalid File Specified .....
                        PLS CHECK
                        • pooya_pm
                          • Jan 2021
                          • 266
                          • iraq
                          Look, it should be
                          PLS CHECK
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3682
                            • slovakia
                            • hard-enduro
                            PLS CHECK
                            need repost. badcaps lost lots of files
                            • m1ch43lzm
                              • Mar 2019
                              • 2012
                              • Peru
                              I have this one as 6050A3348803, check if it matches yours
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3682
                                • slovakia
                                • hard-enduro
                                only simmilar. i have 6050A3249301
                                • m1ch43lzm
                                  • Mar 2019
                                  • 2012
                                  • Peru
                                  https://www.badcaps.net/forum/troubl...23#post3478723
                                  • Supporte
                                    • Jun 2021
                                    • 133
                                    • Brasil
                                    Today I’m working on another board of this model.
                                    I believe that during a Windows update, the BIOS was also updated and something went wrong. Now the laptop powers on, but there is no image and no POST.
                                    What would be the best way to solve this?
                                    Should I reprogram it using its original BIOS backup, or is it better to use this provided file instead?
                                    The board is using an AMD processor.
                                    Any advice would be appreciated.
                                      SMDFlea commented
                                      Editing a comment
                                      post bios requests in the bios forum please, not in the schematic forum.
                                  • majorpopsicle
                                    Asus Prime B550M-A AC Boardview needed
                                    by majorpopsicle
                                    There was a request for this a couple years ago, closest thing posted was a schematic for a different board, could really use a boardview for this, the layout on the matx is different than a similar atx board. Trying to trace an issue with vcore enable, had a high side mosfet explode, the one next to it exploded, cleaned that all up, replaced parts, resistances look great, short is gone, but simply not getting any voltage on the gates on the high side mosfets despite the pwm controller seeming to be intact with no shorts and from what I can tell based on the chip data sheet my inputs are all...
                                    03-28-2026, 09:12 AM
                                  • Draxywezz
                                    needed ASUS TP420UA REV:2.1 Boardview & Schematics
                                    by Draxywezz
                                    Hello guys, i got ASUS TP420UA Rev2.1 no power, and i need the schematic & boardview, hope somebody can help. Thanks in Advance !
                                    12-30-2025, 01:17 AM
                                  • Vish112
                                    Boardview needed for Asus ROG Strix B650E-F AM5
                                    by Vish112
                                    Hi
                                    Me and my 16 year old son have picked up a faulty Asus ROG Strix B650E-F from a garage sale
                                    It boots, but after 15 seconds powers off with a USB overcurrent protection message
                                    Please could you kindly provide the boardview as I am keen to develop his interest in to troubleshooting the usb fuses and USB protection diodes.
                                    Alternatively if you are a passer by and have sucessfully fixed something like this before would be keen to hear your troubleshooting method
                                    We are thinking , bios update by bios flashback first
                                    Then...
                                    09-19-2025, 12:59 AM
                                  • Slavol
                                    Asus UX3407R schematic or boardview needed
                                    by Slavol
                                    Heloo
                                    I’m looking for the motherboard schematic or boardview for Asus UX3407R
                                    board name UX3407QA R2.0
                                    Thanks ...
                                    08-18-2025, 04:05 AM
                                  • byulo
                                    Asus VivoBook UX333FN boardview needed
                                    by byulo
                                    Good day to all folks,
                                    I have motherboard Asus VivoBook UX333FN motherboard, but it is not visible the parts that corroded,
                                    anyone has a boardview. Attach is the picture TIA
                                    Byulo....
                                    08-15-2025, 11:28 PM
