HI, i have this acer JM50 rev 2.1 board to repair for a customer, the board starts on its own after a couple of seconds of plugging, the power button doesn't do anything, the fan spins at almost full speed, after some investigation I found that the board takes it's time to fully calibrate the voltage going into the chips and the entire system then auto starts, I flashed both chips with 3 known working bios, I get no beep nor anything, the PCH seemed to be overheating a bit, I found a missing transistor near the EC chip which I replaced, I require the boardview file cause I found a pin on the ec chip which was ripped off and I don't know where does it go, I appreciate any possible help and thanks forward!
ACER JM50 Rev 2.1 BIOS, schematics and boardview request
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
by Wg188I have an Acer veriton Z4660G all in one pc,
Model: Z4660G-I5850H1 (VZ4660G_W)
Need bios dump and schematic would save my life !
to make a long story short I bought this all in one used
with a broken lcd, with the objective of making a custom desktop out of it
,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...-
by macabookHello everyone,
07-24-2025, 02:17 PM -
by James194ztHi,
My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...-
by ub6ib969Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
Model Number: PO3-650
Part Number: DG.BK4AA.006
Serial Number : 33400117730
BIOS IC : XM25QH256C
I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...-
- Loading...
