Inventec CATALONIA 6050A3022401-MB-A01
  • AL._.EX
    • Dec 2022
    • 890
    • Belarus
    HP EliteBook 830 G6
    Inventec CATALONIA 6050A3022401-MB-A01 schematic​
  • dqtech
    Badcaps
    • Jul 2018
    • 632
    • N/A
    thanks
    • jemi
      • Jun 2022
      • 3
      • Indonesia
      boardview CATALONI-6050A3022401-MB-A01
      • jackx
        • May 2020
        • 221
        • casa1
        hello i need image
        HP EliteBook 830 G6
        • anandkv123
          • Jul 2018
          • 27
          • indiia
          [QUOTE=NikhilSimon;n3661990]Here you go.[
          invalid file showing
            • 21466
            boardview
            • Samuel ade
              • Oct 2024
              • 4
              • Nigeria
              pls i have an 830 g6 laptop that is blinking orange and white 3 times
              i have reprogram the bios chip still same thing 3v 5v present and 1.0 v present
              i dont know what the fault could be
              there is no shoe on the board
              • tomodachi
                • Apr 2012
                • 606
                • Turkey
                Many thanks
                • romky
                  HP Elitebook 850 G8 6050a3216701-mb-a01(a1) Need schematic or boardview.
                  by romky
                  Hello guys,
                  Need schematic or/and boardview for HP Elitebook 850 G8 6050a3216701-mb-a01(a1).
                  01-30-2025, 08:34 AM
                • Henning Høy
                  Schematic & boardview for HP EliteBook 640 G10 - DA0X8TMBE0 Rev: E
                  by Henning Høy
                  Today, I received an HP EliteBook 640 G10, DA0X8TMBE0 Rev: E.
                  I have examined it under my microscope and unfortunately, there are several components on the motherboard (water damage) that need to be replaced. Does anyone here have the schematic & boardview for this model?
                  Thanks in advance.
                  Best regards,
                  Henning
                  09-29-2024, 01:13 PM
                • PacoGT
                  HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                  by PacoGT
                  hello firends
                  i search the schematic or boardview
                  I have this motherboard, but I can't find the schematic or the boardview.
                  The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                  So the computer doesn't turn on, and the 3V disappears after a few seconds.
                  The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                  The new problem arose after removing the bad chip.
                  3V and 5V remained together,...
                  08-19-2025, 08:25 PM
                • hosain0489
                  Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                  by hosain0489
                  I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                  Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                  If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                  Thank you very much in advance!
                  07-15-2025, 11:20 AM
                • re-atari
                  Gigabyte GA-H110-D3A schematic/boardview needed
                  by re-atari
                  Hello all,
                  Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                  This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                  02-24-2025, 06:45 PM
