sony vaio pcg-71311m MBX-223 schematic
  • dj_ricoh
    • 2073
    • uk
    can someoone help me with a schematic for this notebook?
    MBX- 223 REV 1.1 M971
    i got no backlight on the led screen
    ty
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: sony vaio pcg-71311m
    here it is.
    • trodas
      • Jan 2006
      • 770
      • Czech republic
      Wow!
      I see at least two 330uF caps, witch is something that is nowhere near to be found in the Sony Vaio PCG-7144M notebook I should repair for my friend...
      Dear spidey, do you have schematics for the Sony Vaio PCG-7144M also? Pretty please with suggar on top?
      "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
      "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        need motherboard id. mbx-223 or mbx 224 or whatever.
        • trodas
          • Jan 2006
          • 770
          • Czech republic
          Where can I find the motherboard id? There is not much info on the mobo. There is on the PCB:
          HannStar J MV-6
          94V-0 0835
          and
          MDC Conn.
          ...and that it is. On the "USB Board 6 Layer" are some more words:
          HannStar J
          M790 MV-6 Rev: 1.1 CNX-438 94V-0
          USB Board 6 Layer
          1P-1087500-6011 + s/n sticker: WR-89D-YH8-1194
          But a different s/n is on the "Power Button Board" - ending with 2608 and there is also visible the M790.
          Printed in the plastic at the top of the back of this NTB bellow the battery are these texts:
          4-1114-960-
          C-3598
          FOXCONN A
          TJC
          TN7100F
          >PC+ABS<
          ...and two tables, one from A to J with dent in A. Second with 08, 09, 10 values (presumably years) and then following 12 places (presumably moths) and in the 08 year is dent in the 9th table place.
          Probably creation date September 2008...?
          Then there is another sticker - 013-001A-8954-A with barcode. Same on GPU heatsink, both ram slots and WiFi adapter as well as on some cables... Hard to locate anything that even remotely says mbx-223 ... Please advise.
          PS. are there components on the backside of the PCB?
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            did you remove motherboard out of the case ? laptop motherboards are double sided. check the other side.
            • trodas
              • Jan 2006
              • 770
              • Czech republic
              Nope, I did not. These seems to be too many connections, so I did not wanted yet to push for it, before I know what could be wrong.
              So, is the mainboard possible to identify somehow?
              • spidey
                climbs
                • Dec 2012
                • 644
                • Cyprus
                sorry cant help you without a code.
                • Bisketti
                  • Oct 2013
                  • 252
                  • Ireland
                  Sony VPCE range Board MBX-223 schematic
                  Hi folks I have a spillage damaged MBX-223 i3 CPU here initially was dead /no power. The bios pins and pad were damaged swapped bios from same model scrap board and repaired traces. Unit now powers up with no Video it only draws max 1/2Amp on the bench supply.
                  The GFX core was 0v so after checking around the regulator (PU25) and replacing pr127 and also Pu25 Im now getting 0.88v- 0.90v on coil PL19 (GFXCORE) . The screen continues to stay black on draw 1/2a and after a minute or so fan spins very fast also it will not switch of using powerbutton but will switch on?.
                  Any ideas would be great
                  • derick
                    • Aug 2012
                    • usa
                    ty
                    Hi, have you fix it? From the LCD's LCDVCC(point 2 and3), where does it go to? I couldn't find U17.
                    • karim011
                      • Nov 2016
                      • 121
                      • Morocco
                      Needed schematic SONY
                      Hi. Needed schematic for sony mainboard ID : MBX-223 M971 Rev : 1.1
                      • peste
                        • 12887
                        • ROMANIA
                        Re: Needed schematic SONY
                        can help you that..
                        • a0005136
                          • Jul 2021
                          • Philippines
                          thank you
                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 05:27 AM
                            Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                            This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                            Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                            This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          • Carlos#2003%
                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                            by Carlos#2003%
                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                            02-15-2024, 07:52 PM
