daax3mb16a1 rev:a DDR2 version schematic needed.
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: daax3mb16a1 rev:a DDR2 version schematic needed.
    np, hope you fix it.
    • scobie_21
      • Jul 2011
      • 144
      If you get a chance will you download that schematic again please there seems to be some corrupt info in the file.
      • scobie_21
        • Jul 2011
        • 144
        The +1.05v is short to ground I have removed PL2 out of circuit to eliminate PU2 and short circuit is occuring post PU2 circuit. What is the most likely culprit likely to be or what is the easiest way to pin the short down.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          yes, but unfortunately file has some corruption. But you may try to fix the pdf file with a software. +1.05 is supply for cpu, try to measure it without cpu.
          • scobie_21
            • Jul 2011
            • 144
            Yeah I had cpu out, its the same with or without CPU in.
            • Francisco.s
              • 686
              • Spain
              #26
              Originally posted by The_Boss
              Would be nice to find one.
              Theres a 8 pin SMD IC marked M113 near USB ports that I need to replace. The problem is - I have no idea what exactly is it so I can´t search it.
              PD14, is at the very beginning of the DC input, so if there is a short, and pd14 is not the problem, then check PC142, PC151 and +VAD line.
              I can´t find M113, can you say the number of the IC?
              • scobie_21
                • Jul 2011
                • 144
                #27
                Thanks bu they all seem fine, there is no ic marked m113 there only 8 pin is U8 which is G547F2P81U.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #28
                  Yes, my IC was so burnt, I did not see G547F2 written there. But I fixed my problem some days ago.
                  • scobie_21
                    • Jul 2011
                    • 144
                    #29
                    Any ideas what pulling down my +1.05v ?
                    • spidey
                      climbs
                      • Dec 2012
                      • 644
                      • Cyprus
                      #30
                      change pq39 wheter if it is good or bad.
                      • scobie_21
                        • Jul 2011
                        • 144
                        #31
                        Thanks again all sorted now
                        • spidey
                          climbs
                          • Dec 2012
                          • 644
                          • Cyprus
                          #32
                          thx for myself , i need this schematic now !
                          • spidey
                            climbs
                            • Dec 2012
                            • 644
                            • Cyprus
                            #33
                            scobie, do you still have the board ?
                            • repairs
                              • Nov 2013
                              • 10
                              • india
                              #34
                              I download this file AX3E-DDR2.pdf but some images not view properly. it says that this file is corrupted
                              • speedypro
                                • Feb 2013
                                • 561
                                #35
                                Originally posted by scobie_21
                                Hi folks
                                I am looking for a schematic for this daax3mb16a1 rev:a DDR2 version I am told its from a HPg56 I have the DDR3 schematic but am trying to identify this component.Pd12 is short and cracked so I cannot see what it is I have checked a few components on the ddr3 version and there seem to be differences.
                                Any assistance is appreciated
                                If anyone looking for that part, it is a diode with markings: PJ0366 1V
                                Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
                                • danieltoader69
                                  • Apr 2013
                                  • 39
                                  • romania
                                  #36
                                  try this
                                  • fyaagoub
                                    • 269
                                    • maroc
                                    #37
                                    • Nat123
                                      • Aug 2019
                                      • 24
                                      • Peru
                                      #38
                                      Originally posted by spidey
                                      Thanks is enough
                                      found it in a chinese site..
                                      • nassimhamdi
                                        • Feb 2016
                                        • 152
                                        • algeria
                                        #39
                                        thank you
                                        • Kgotla
                                          • Jul 2020
                                          • 5
                                          • South Africa
                                          #40
                                          Can I get schematics on DAAX3MB16A1 REV A AX35E. The schematics here aren't the once I'm looking for. Thank you!
