please anyone have nec ms-13821 ver 1.0 schematics and boardview
by CG_DionysosHello,
I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
Thanks in advance!
Greetings from Germany...-
09-16-2025, 06:43 AM -
by Tribalus43Request: Lenovo ThinkPad T14 Gen 2 (Intel) Schematics/Boardview
I’m looking for the schematics or boardview for a Lenovo ThinkPad T14 Gen 2 (Intel) with the following board:
HT4B07HP4B0 / HT5B1 / HP5B1 / HT4B2 NM-D352 Rev: 2.0
I’m currently dealing with some startup issues and would like to test for shorts. Any help would be greatly appreciated.
Thanks!
09-01-2025, 12:10 PM -
by PacoGThello firends
i search the schematic or boardview
I have this motherboard, but I can't find the schematic or the boardview.
The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
So the computer doesn't turn on, and the 3V disappears after a few seconds.
The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
The new problem arose after removing the bad chip.
3V and 5V remained together,...-
08-19-2025, 08:25 PM -
by hosain0489Hello everyone,
I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
Thank you very much in advance!
by Jag013Hi, I need the boardview and schematicsfor an HP OMEN 15-ax204ns laptop, purchased in 2018, with the following specifications:
- Processor: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
- RAM: 4.00 + 4.00 GB
- Hard Drive: 1TB
- Product ID: 00325-96088-89605-AAOEM
- N/S: 5CD70805T8
If you can help me locate the boardview and schematics or a boardview file, I would really appreciate it.
Thank you for your help!...-
- Loading...
