6050a3158801-mb-a02 schematic
  • naseee
    • Nov 2016
    • 102
    • india
    check this
  • ender_33
    • Oct 2016
    • 7
    • venezuela
    Re: 6050a3158801-mb-a02 schematic
    Originally posted by naseee
    check this
    thanks
    • TheJeanox
      • Jul 2022
      • Chile
      Thanks!!
      • Qbinhelec
        • Mar 2023
        • 27
        • Việt Nam
        thankyou
        • fharlock999
          • Nov 2017
          • 62
          • Chile
          thanks
          • akmalbek
            • Feb 2021
            • tashkent
            thank you
            • winkoko
              • Feb 2013
              • 28
              • myanmar
              • M4n0l0307
                • Nov 2020
                • 167
                • Colombia
                Thanks Friend !
                • MaheshGlobal
                  • Apr 2025
                  • India
                  '' Thanks friend ''
                  • redappleguru
                    • Oct 2012
                    • 27
                    • india
                    Many Thanks
                    • TinkerTron
                      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                      by TinkerTron
                      Hey everyone,
                      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                      Instead, here's what's been bugging me so far:
                      The schematic...
                      03-06-2025, 02:03 PM
                    • atunguyd
                      Acer x163w Monitor PSU schematic
                      by atunguyd
                      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                      03-05-2025, 02:08 PM
                    • dreico33
                      TL866 II Plus Check ID Error on various IC
                      by dreico33
                      Hellow guys , i really need your help here.
                      Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                      11-04-2024, 03:13 PM
                    • hasel17
                      CH341a can erase and read but can't write and blank check
                      by hasel17
                      So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                      Code:
                      Checking for blank...
                      (Press
                      10-26-2023, 06:20 AM
                    • EasyGoing1
                      LED Array Schematic Check?
                      by EasyGoing1
                      Was wondering if someone would double-check my design here. It's relatively simple. I used an online LED array calculator to get the core array specs. And for the potentiometer, I figured that since the sum of the parallel resistors (since I don't know the internal resistance of the LEDs) is 5.5 Ohms, that adding a 5 ohm pot for dimming would be sufficient, if not overkill possibly.
                      Each LED is rated at 3.2V 150ma
                      VCC = 19V from a laptop power supply, so it should be a fairly stable source voltage.
                      I need the thing to be stable and to be able to dim...
                      12-26-2021, 02:45 PM
