MACBOOK PRO a1278 820-2530 EMC 1413 BIOS
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    When i turn on macbook i do hear mac sound but screen is blank
    SORRY EMC IS 1413 NOT 1403
    i need bios for it
    thanks
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    Re: MACBOOK PRO a1278 820-2530 EMC1403 BIOS
    i need bios for it
    thanks
    post the original bios...
    • NConstantinou
      • May 2017
      • 335
      • Cyprus
      ehen i tried to read this file using RT809F was giving me reading error
      EMC 3089 is writen on IC.
      i mentioned what was on schematic diagram.
      i hope this is correct
      • NConstantinou
        • May 2017
        • 335
        • Cyprus
        Re: MACBOOK PRO a1278 820-2530 EMC 1413 BIOS
        Can someone help!!!!
          • 20977
          Can`t find an EMC 1413 ? .Try this bios https://www.badcaps.net/forum/showthread.php?t=67499
          Mac Specs: By Identifier: EMC Number
          https://everymac.com/systems/by_capa...mc-number.html
          • NConstantinou
            • May 2017
            • 335
            • Cyprus
            Happy New Year
            Thanks for your reply,
            From your links and and and from what i have (board) the processor is 2.26MHz core 2 Duo 13".
            On SMC ic is written 3089 or 3039 and 340D.
            This board i purchased from ebay and unfortunately the seller disappeared therefor i can not contact for more info.
            the board when was received supposed to be a working one but it was defective and i fixed it.
            I used schematic macbook pro A1278 820-2530 that was more near to board.
            So i went thru the RAILS test and all voltages are there. the only difference i have is PPVCOPE_S0_CPU i got 1.08v and on schematic says 1.5v.
            That is why i said it is a bios problem.
            do you have any suggestions.
            There is one IC U9000 pin1 is LVDS_IG_PANEL. there i have .2v and sometimes .5v but there is no short. pins 2&3 have 3.3v.
            tracing pin 1 goes to a resistor which is 0v ( measure resistance is ok) and
            then goes to graphics ic. Pin 1 should be 3.3v.
            can i fet from somewhere!
              • 20977
              Happy New Year
              Happy new year to you too. This is just the Bios requests sub forum, start a new thread if you want more help here -> https://www.badcaps.net/forum/newthr...newthread&f=23
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • Bloodhoundje
                HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                by Bloodhoundje
                I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                I have desoldered the bios chip (GigaDevice...
                03-16-2024, 03:12 PM
              • traxformania
                TONGFANG "GM7TG7P" Bios Password Problem?
                by traxformania
                I tried :
                -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                11-15-2023, 07:32 AM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
