please help remove password dell lat.5320-8fc8
  • bykanovm
    • Aug 2022
    • 95
    • Украина
    #41
    Re: please help remove password dell lat.5320-8fc8
    Help me remove ST password: J1C35B3
    have a script that deletes such passwords, but after the first turn on, I go into the BIOS, register the service tag, and disable Absolute. After which the laptop reboots, but there is no image. The keyboard backlight flashes and that's it. If you disconnect the battery and connect it again. You can only get into the BIOS once. Then there is no image either.
      • 22035
      Are the scripts from this site or somewhere else.Post the bios that you patched
      • farouk_1994
        • Mar 2021
        • 399
        • algeria
        #43
        Try this file than replay
        • bykanovm
          • Aug 2022
          • 95
          • Украина
          #44
          Here is the BIOS that I tried to unlock, but it had the problem described above.
          I compared with the Patched file above. The files are identical.
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            #45
            Try this one
            • bykanovm
              • Aug 2022
              • 95
              • Украина
              #46
              I had a problem with the BIOS chip 25R256DYIG. It's out of order. I'm trying to find the same one. There is 25B256DYIG available, but with it the laptop turns on, starts turning the fan at full power and turns off.
              • volinakis
                • Jan 2021
                • 2874
                • N/A
                #47
                you can use winbond W25Q256JV or W25Q256FV (not JW). also 25B256DYIG is compatible, write .bin I modified and see if it works.
                • bykanovm
                  • Aug 2022
                  • 95
                  • Украина
                  #48
                  Very strange laptop behavior. I think that the 25B256DYIG chip is not quite suitable for this model. With your file, the laptop spins the fan at full power and there is no image. I recorded the original file to check. The laptop behaves differently with it. The fan is not noisy at all. But the screen lights up white, then red, green, blue. It's like there's a display test going on. I think that you need to select a different BIOS chip.
                  • volinakis
                    • Jan 2021
                    • 2874
                    • N/A
                    #49
                    let it run for 2mins with new bios, it will restart several times with no image.
                    • bykanovm
                      • Aug 2022
                      • 95
                      • Украина
                      #50
                      I've been waiting a long time. The indicator also tells me that the BIOS flash memory is damaged. Flashes 3 orange and 6 white.
                      • volinakis
                        • Jan 2021
                        • 2874
                        • N/A
                        #51
                        so it means your bios dump was damaged. try this reconstructed bios.
                        • pokyss1
                          • Mar 2019
                          • 60
                          • TUNISE
                          #52
                          dell latitude 5320
                          service tag GNHBQ93
                          • Ghamidi
                            • Mar 2020
                            • 306
                            • France
                            #53
                            dell latitude 5320
                            service tag GNHBQ93
                            Try...
                            • pokyss1
                              • Mar 2019
                              • 60
                              • TUNISE
                              #54
                              Originally posted by Ghamidi
                              Try...
                              thax .working good
                              • cesaro
                                • 28
                                • N/A
                                #55
                                hello ,
                                Need to remove password dell latitude 5320 8fc8
                                Thank's
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  #56
                                  Originally posted by cesaro
                                  hello ,
                                  Thank's
                                  pplease share service tag?
                                  • cesaro
                                    • 28
                                    • N/A
                                    #57
                                    i update the post thank's
                                    • cesaro
                                      • 28
                                      • N/A
                                      #58
                                      any one can unlock it ?
                                      thank's
                                      • qayyum786
                                        • Aug 2018
                                        • 1959
                                        • INDIA
                                        #59
                                        TRY
                                        • cesaro
                                          • 28
                                          • N/A
                                          #60
                                          top , it's working thank's a lot of
                                          • Applefixparis
                                            Dell XPS 13 9315 Password Remove
                                            by Applefixparis
                                            Please Remove Password of this Bios
                                            Model : Dell XPS 13 9315
                                            Motherboard : HDP 33 LA-L231P
                                            Rev : 1.0 (A00)
                                            Serial No : J49MHR3...
                                            08-05-2025, 11:23 AM
                                          • hopkok
                                            Dell Inspiron 11-3147 password remove help
                                            by hopkok
                                            Hi, can anyone help me to remove password from Dell Inspiron 11-3147?
                                            Service tag:3N12812
                                            I flashed main BIOS, password removed, but getting BSOD : ACPI BIOS ERROR
                                            Main BIOS attached.
                                            I tried bios password generetor website linked here, did not helped.
                                            Thank you...
                                            12-18-2023, 10:20 AM
                                          • CuteWildCat
                                            BIOS Admin Password remove for Dell Optiplex 3090 SFF
                                            by CuteWildCat
                                            Hello there,
                                            My Dell Optiplex 3090 bios is locked with admin password. Worst of all, it seems.
                                            Here is my system number 1THQMS3-8FC8.
                                            I don't have the hardware to dump my bios, and I can't pay 400€ to hope to get a password from a guy I don't even know exists. So without conviction I'm wondering if anyone here can help me.
                                            Thank you in advance...
                                            01-01-2025, 02:23 PM
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            Yesterday, 10:04 AM
                                          • snpetit
                                            Asus FA706IH Bios Password remove
                                            by snpetit
                                            i need some help :-/
                                            i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                            Could you please remove all password related stuff from this bios. A hate Asus....
                                            Thanks in advance!...
                                            01-10-2025, 09:17 AM
