ST:5SYS8S3
Dell Latitude 5530 bios dump??
hi tryAttached FilesPremium supporters get full download access and other benefits.
Hello! I have two Dell Latitude 5530's with 3FE2 passwords that I need removed. They also have two chips, one 16mb and one 32mb, so I'm guessing this is a dual chip bios? The 16mb is on the visible side of the motherboard, and is named "winbond 25r128jvsn". The other chip, on the opposite site of the board, is a 32mb wson8 chip named "winbond 25q256jven 2213 6151 8w600". I tried to get the dump from this one first using the QFN8 probe but that didn't work so I have another one coming that has the little plastic piece at the end of the probes. I've also tried to desolder it from the board using a hot air gun and flux but that didn't work either.
I figured while waiting for the other probe I could get the dump from the 16mb chip, and was able to, but now that laptop won't boot. I'm guessing cause I fried the chip with the hot air or something? I did clean all the flux off the board after failing to get the wson8 off. I really want to learn how to do this myself, but I'm obviously running into trouble. I also lost the paper that had the BIOS code for the first one down, and since it won't boot I can't get it. I'm pretty sure it's the 3FE2 though. All I've got is the information below and the 16mb dump. And if the South Peak stuff isn't the information you need, I also have a picture of the decal on the board with the CN, MO and P/N. Grateful for any help!
Dell Latitude 5530
Service Tag -9WKFPT3
BIOS CODE - 3FE2?
Board ID -
South Peak 15 MLK MB DDR4
203102-1
FK8VG$LA
try https://www.badcaps.net/forum/troubl...66#post3872366Hello! I have two Dell Latitude 5530's with 3FE2 passwords that I need removed. They also have two chips, one 16mb and one 32mb, so I'm guessing this is a dual chip bios? The 16mb is on the visible side of the motherboard, and is named "winbond 25r128jvsn". The other chip, on the opposite site of the board, is a 32mb wson8 chip named "winbond 25q256jven 2213 6151 8w600". I tried to get the dump from this one first using the QFN8 probe but that didn't work so I have another one coming that has the little plastic piece at the end of the probes. I've also tried to desolder it from the board using a hot air gun and flux but that didn't work either.
Dell Latitude 5530
BIOS CODE - 3FE2?
Board ID -
203102-1
FK8VG$LAComment
Hi, please clear me
Dell Latitude 5530
sn: C18KXL3
SOUTH PEAK 15 MLK MB DDR4
203102-1
FK8VG$JA
Hi, here is your requestAttached FilesPremium supporters get full download access and other benefits.
DELL LATITUDE 5530
SERVICE TAG: JT9ZWL3
MOTHERBOARD: SOUTHPEAK15 MLK MB DDR4 203102-1 FK8VG$LA
Please remove the password
Make another GOOD backup using this small tool > https://www.badcaps.net/forum/troubl...55#post3863055
ONLY then try this file, if it doesn't work then post the other GOOD backupAttached FilesPremium supporters get full download access and other benefits.
HI i have Dell 5530 problem is dell log came and restar i try to me clean but same can any one rebilud hare is bios file 15 ADL MLK 3RD MB 8L 213179-1 7X5T8$LA ST-7S4JBS3Attached FilesPremium supporters get full download access and other benefits.
Hi, try these files and give feedback
Dell Latitude 5530 System BIOS (SKU 0B06) Version : 1.9.0Attached FilesPremium supporters get full download access and other benefits.
After a BIOS update, I have the famous "TPM not detected" ; I did a recovery BIOS procedure (Ctrl+Esc) , I also upgrade the Bios with the latest one, same error.
Could you help me?
Thank you in advance.
Latitude 5530
Motherboard: South Peak 15 MLK MB DDR4
203102-1
FK8VG$KA
Dell P/N: 0941DD
S/T: 6V6GTL3Attached FilesPremium supporters get full download access and other benefits.
Hi, first write both of these files and see if it fixes the issueHello,
Could you help me?
Latitude 5530
203102-1
FK8VG$KA
Dell P/N: 0941DD
NEWS:
It seems that "discrete TPM" disappears, only PTT (intel ones) still remains.
miss Intel Management Engine Consumer Firmware, consumer gigabit ethernet and
Emza Sensor controller (Cf. picture.).
I'll try your 32GB file.
NB: in the BIOS, the "TPM2.0" section is missing.Comment
Device: Laptop
Brand : Dell
Model: Latitude 5530
Board: Southpeak 15 adl mlk 3rd mb 8l 213179-1 7x5t8$ja
ST: 4ZX6CS3
Issue : power on full fan no picture
request repair pleaseAttached FilesPremium supporters get full download access and other benefits.
dear team
please fix by bios
alert!tpm device not detected
dell lattitude 5530
st:-h7vm8s3Attached FilesPremium supporters get full download access and other benefits.
Dell Precision 3570 and Latitude 5530
System BIOS (SKU 0B06, 0B08) Version : 1.36.0Attached FilesPremium supporters get full download access and other benefits.
So I flashed your 2 files, but it is EXACTLY the same.NEWS:
So better flash only the 16MB EEPROM, it's fast and very easy to remove (big soic8 and very little things to remove), no need hot gun. :-)Comment
by TrademarkHello everyone,
Iโm hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
This is NOT a BIOS password removal request.
Iโm looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone elseโs BIOS.
Laptop Information- Model: Acer Predator Triton 16 PT16-51-99GL
- Motherboard: DA0ZQDMB8AE Rev. E
- Main SPI flash: Winbond W25Q256JVEN (32MB)
- Secondary
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by prontoHi can you help me to repuild bios dump fo dell latitude 9450 2-in-1 ultra 7
original problem was password but the chip 512mb its broken before read it
motherboard/JDB45-LA-M397P
ST/2PFD064
here dump of anoher laptop 9450 2-in 1 but not working whit first laptop...-
by Kqz1310Hello I need help to unlock bios password in my Dell latitude 5530
winbond 25R128JVSN...-
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos - Loading...
