hekp removing bios lock passoword asus k3500pc
  • cesar888
    • Jun 2019
    • 13
    • Portugal
    hi guys
    need help to clean password or were to find in the bios bin hex.
    thanks o lot
  • hardware1
    • Sep 2021
    • 2925
    • N/A
    Re: hekp removing bios lock passoword asus k3500pc
    Originally posted by cesar888
    hi guys
    thanks o lot
    Wrong chip, find another one.
    all donations are welcome,
    • cesar888
      • Jun 2019
      • 13
      • Portugal
      Why you say that?
      This is the original chip
      • hardware1
        • Sep 2021
        • 2925
        • N/A
        Why you say that?
        This chip is 1MB! your chip must be 8MB, 16MB, 32MB or something like that.
        • cesar888
          • Jun 2019
          • 13
          • Portugal
          Yes but it works fine if you write the bin on chip,i tried to use the bios from asus website but it has 27mb archive when extracted.
          The laptop is a asus vivobook pro i7 11gen . When i use MEanalyzer it says that needs to be extracted with ami extract
          • cesar888
            • Jun 2019
            • 13
            • Portugal
            The tutorial bios that is here on forum dont explain the process to clean or reset on the new asus laptops.
            I studied the process but isnt complete the tutorial and on the internet i dont find nothing about it.
              • 20656
              Why you say that?
              Its 8 megabits ,which equals 1 mega byte. What youve posted isnt even a proper backup of the chip.The chip is for something,not sure what but could be for the thunderbolt or USB-C firmware.
              Did you make a backup before you overwrote it .As hardware1 said,the bios chip is somewhere else.
                • 20656
                AMI PFAT extract will only remove the PFAT header, it still needs editing to the correct size using a hex editor. It is not a full bios image,only an update, it is the bios region, there is no ME firmware,no flash descriptor. The update can/could be merged with your bios backup and the DMI copied (if you could find the correct chip... ) . Thats one way to get rid of the password,but there are other ways as well.
                • cesar888
                  • Jun 2019
                  • 13
                  • Portugal
                  i will search in the motherboard another bios chip to saw if it containt more information.
                  i used the ami pfat on bios that i readed and the bios from asus site
                  and it show this files that i attached.
                  i maked 2 backups from the chip before the write process.
                  sorry for the bad inglish and thanks a lot for the response and attention.
                  i like to learn, im curious and i search endlessly for the solutions.
                  • cesar888
                    • Jun 2019
                    • 13
                    • Portugal
                    i find the bios its here
                    • hardware1
                      • Sep 2021
                      • 2925
                      • N/A
                      Here's your Unlocked file, hope it works fine.
                      • cesar888
                        • Jun 2019
                        • 13
                        • Portugal
                        It worked.
                        Thanks a lot
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • lrouw84
                          by lrouw84
                          Hi there,
                          01-28-2023, 01:31 PM
                        • DynaxSC
                          by DynaxSC
                          06-14-2024, 03:49 PM
