Asus E410MA r5.1 bios dump request
+ More Options
Posts
  • zoltor
    • Nov 2016
    • 30
    • Казахстан
    Hi, please very need bios dump for asus E410MA R5.1, other version revision not working. 5.1 i can't find. Thank you. Symptoms: when plug the adapter power key white lightening, charge led - orange and no init. When the hold press power key, laptop goes of and on again. I cant shutdown laptop, when adapter powered. From battery laptop shutting down but no init
  • zoltor
    • Nov 2016
    • 30
    • Казахстан
    Re: Asus E410MA r5.1 bios dump request
    Old bios dump missing another serviceman.
    • hardware1
      • Sep 2021
      • 2925
      • N/A
      Here are 2 bios files from Asus, you must have a sticker on your motherboard leading you to the right file that you should use. Otherwise you can try them one by one.
      all donations are welcome,
      • zoltor
        • Nov 2016
        • 30
        • Казахстан
        Hi, no sticker on motherboard. Asus E410MA r5.1 - this written on board. Thank you i check your files and respond.
        • zoltor
          • Nov 2016
          • 30
          • Казахстан
          Unfortunately, it doesn't work. MA dump behaves the same, MAB can be turned on with the battery disconnected, but still no initialization. With MAB, the processor gets very hot.
          • cellwina
            • Jan 2021
            • 7
            • romania
            Hi, same issues as zoltor
            this is the original dump
            • hardware1
              • Sep 2021
              • 2925
              • N/A
              Here's your New bios file, try it and let me know.
              Model Number: E510MA-BQ589
              Serial Number: M8N0CX20Y52434B
              This thread for E410MA not E510MA, next time find your device thread or make your own.
              • cellwina
                • Jan 2021
                • 7
                • romania
                thanks for the file, but same issue. sorry i posted here but on my board it says e401ma and has the same issue and i tought its better to post here. next time i will know.
                • hardware1
                  • Sep 2021
                  • 2925
                  • N/A
                  This is your device Serial Number or not? (M8N0CX20Y52434B)
                  Also look for a sticker on your motherboard and upload a photo for it.
                  • cellwina
                    • Jan 2021
                    • 7
                    • romania
                    on the mb says 410, on the bottomcase says 510
                    • hardware1
                      • Sep 2021
                      • 2925
                      • N/A
                      Can you see a sticker like that on your board or a QR Code sticker?
                      • cellwina
                        • Jan 2021
                        • 7
                        • romania
                        this is the only Qr found on board.
                        • razadom
                          • Apr 2015
                          • 100
                          • Madagascar
                          Hi all
                          somebody found solution to solve this problem or not. Same problem like zoltor.
                          When i plug adapter, charge led flash white, power key white lightning but no
                          init
                          • mohiuddin
                            • Nov 2020
                            • 4
                            • bangladesh
                            thx boss 100% ok
                            • hardware1
                              • Sep 2021
                              • 2925
                              • N/A
                              Originally posted by mohiuddin
                              thx boss 100% ok
                              You're welcome.
                              • juandi9191
                                • Dec 2020
                                • 8
                                • colombia
                                as-304 working fine in rev5.1
                                • MDSI
                                  • Apr 2022
                                  • 22
                                  • France
                                  Hello !
                                  I have an Asus E410MA that came to me with a password on the bios.
                                  I wanted to flash the bios with one of those provided by asus but they only provide files with the extension .306 and I do not understand how to exploit this.
                                  I searched the forum and found a lot of interesting information and tutorials but either I do not understand or I looked in the wrong place.
                                  Could someone help me first to remove this password from this bios and why not, explain to me how it was done?
                                  Thank you in advance!
                                  E410MA Password.rar
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1219
                                  • France
                                  SERIAL: MAN0CX26B278438
                                  try
                                  • MDSI
                                    • Apr 2022
                                    • 22
                                    • France
                                    Thank you!
                                    After testing, I think I burned the regulator used to power the bios by using a programmer of very dubious manufacture, I'm ordering a new regulator and a programmer worthy of the name and I'll tell you if everything works as soon as possible.
                                    Thank you!​
                                    • MDSI
                                      • Apr 2022
                                      • 22
                                      • France
                                      Well, i replaced the regulator, i flash the bios and all is working well !
                                      Thanks !
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                        09-07-2024, 02:50 AM
                                      • DynaxSC
                                        by DynaxSC
                                        06-14-2024, 03:49 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
