The modified bios solution to deactivate the soldered ram works but the problem is that windows downloads the updated bios version through updates and once the bios is updated the soldered ram deactivation fails. I solved it this way instead. I downloaded the latest bios from the Lenovo site, I cut the parts relating to the flash software, I modified the bios to deactivate the soldered RAM. Now the machine works, if I enter the bios the serial entry is invalid. In this way Windows will no longer be able to automatically update the bios because it does not recognize the serial number and therefore the change remains permanent except if it is updated manually by downloading from the site (I'm not sure but about this) Me engine cleaned. I attach the bin file if anyone needs it
Lenovo nm-d031 onboard ram disabled bios
Isn`t there a bios setting to turn off bios capsule updates. This model can be disabled via resistor straps, it`s a permanent solution with no need to worry about the bios updating.The modified bios solution to deactivate the soldered ram works but the problem is that windows downloads the updated bios version through updates and once the bios is updated the soldered ram deactivation fails. I solved it this way instead. I downloaded the latest bios from the Lenovo site, I cut the parts relating to the flash software, I modified the bios to deactivate the soldered RAM. Now the machine works, if I enter the bios the serial entry is invalid. In this way Windows will no longer be able to automatically update the bios because it does not recognize the serial number and therefore the change remains permanent except if it is updated manually by downloading from the site (I'm not sure but about this) Me engine cleaned. I attach the bin file if anyone needs itComment
Why disable onboard ram with bios when hardware moded solution is already posted in the forum.
Bios method should be used when it cant be disabled by hardware.
Once the customer updates bios or gets the same thru windows update, you know what'll happen.Comment
You know why, no soldering needed. Windows firmawre update can be disabled.Comment
I have a question the laptop i fixed is for my customer and the problem wasn't the bios but the onboard ram itself, i dont have any resistor straps lying around and what can be my solution to fix the onboard ram to not enable? i worry that they might do an update via windows update and it would revert back.Comment
by BloodhoundjeHi everyone,
I have desoldered the bios chip (GigaDevice...-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by JOOYOUNGHi everyone,
I'm trying to modify the onboard RAM SPD data inside a BIOS file.
I just want to update or replace the SPD information properly so that the system can recognize the correct memory specifications.
I already know that BIOS is hard-coded and that not everything can be simply copy-pasted.
But my goal is only to update the SPD data itself — nothing related to hidden menus or enabling extra BIOS features.
For reference, my laptop model is RZ09-0472, and I found the SPD information I need from an ASUS BIOS.
I have uploaded both my...-
04-27-2025, 03:13 PM -
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... - Loading...
