Unowhy Y13 BIOS Password Request
Hello i have Y13 2022 bios locked
SN:IFP225120008Attached FilesComment
Hello guys. i have this model Y13G201S4EI WITH BIOS password; I need help to remove it.
N;IFP424026497
Attached Files↵
https://www.badcaps.net/donateComment
Greetings, need bios unlock for unowhy y13g201s4ei
N : IFP427052978
JUIN 2024Attached FilesComment
Attached Files↵
hello, i have 2 pieces Y13 with bios password, can someone help unlock?
thanks
Unlocked↵
tryAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Every donation made will go towards server fees and maintenance costs.Comment
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by BlackVisorRedmiBook Pro 1542022 6800H
SKU: TM2113-39463
Model Number: RMA2204-AB
CMIIT ID: 2022AP1835
SN: 39463/22WD01355
BIOS version: RMARB5B0P1010 20230628
1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...-
01-14-2024, 06:35 AM -
- Loading...
