Thinkpad E480 BIOS Dump
  • robante15
    • Nov 2020
    • 58
    • El Salvador
    I have a Thinkpad E480. Type 20KN-003ULM
    The problem it presents is that it turns on the power LED light but it never gives video. Last time it worked I left it on and unplugged. It probably discharged and never turned on again. What I found out is that a Firmware update came out that day, I would believe it was attempted to update and ended up with a corrupted BIOS update.
    I have tried with other DUMP bios from other posts and they have not worked for me. Here I leave a backup of my non-functional BIOS, I hope someone can help me with my problem.
    From now, thank you for you help
  • hardware1
    • Sep 2021
    • 2927
    • N/A
    Re: Thinkpad E480 BIOS Dump
    Here's your new file, try it and let me know the results.
    all donations are welcome,
    • robante15
      • Nov 2020
      • 58
      • El Salvador
      I have tried the file and at least on my computer it didn't work.
      I would think it may be an EC problem. Unfortunately I do not have an EC programmer
      • hardware1
        • Sep 2021
        • 2927
        • N/A
        Didn't work mean no power or no display? is it doing the same symptoms like the other files?
        • robante15
          • Nov 2020
          • 58
          • El Salvador
          Turns on the power LED, but no image
          It also doesn't turn on the fan, nor the keyboard LED. But it does charge the battery.
          And yes, the behavior is the same as with other files
          • hardware1
            • Sep 2021
            • 2927
            • N/A
            I see that your file has EC Region, i have replaced it so you can give this file a try.
            • robante15
              • Nov 2020
              • 58
              • El Salvador
              the same behavior
              • repairit.ie
                • Jan 2020
                • 8
                • Ireland
                Hi Everyone!
                need bios please.
                Laptop turns on but black screen.
                can someone post the bios for Lenovo thinkpad e480
                Mobo type: 20KN-CT-1WW
                S/N: PF-1J9TLL
                Thank you in advance!
                • hardware1
                  • Sep 2021
                  • 2927
                  • N/A
                  Originally posted by repairit.ie
                  Hi Everyone!
                  need bios please.
                  S/N: PF-1J9TLL
                  Here's your New BIOS, try it and let me know the results.
                  • repairit.ie
                    • Jan 2020
                    • 8
                    • Ireland
                    Still no display
                    laptop charging battery, turns on but no display. Checked the usual suspects but board still not working properly.
                    • skazide
                      • Jul 2015
                      • 142
                      • morocco
                      still no display
                      try this
                      • dysk1
                        • Aug 2019
                        • 11
                        • Tychy
                        Lenovo E480 NM-B421 please repair the bios
                        I bought a damaged laptop, one RAM slot was not working. I thought it was the Bios fault, so I uploaded one from this forum, unfortunately the laptop did not turn on anymore. I uploaded the original bios back, but the laptop no more turns on.
                        The laptop is charging the battery, 3V and 5V are present. After pressing the power button no reaction.
                        Attached is the original bios and all data. Please fix the bios.
                        • akwky
                          by akwky
                          Hi!
                          04-14-2025, 01:56 PM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • Joluvillas
                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                          by Joluvillas
                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                          06-18-2024, 10:35 PM
                        • mikeybass
                          by mikeybass
                          04-23-2025, 04:30 PM
                          Lenovo ThinkPad E480 Notebook E Specification for Upgrade or Repair
                          This specification for the Lenovo ThinkPad E480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E480 boardview and E480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                          09-06-2024, 02:28 PM
