bios password Lenovo L440
  • rachidell
    • Aug 2016
    • 137
    • algeria
    HI .can you remove password from lenovo l440
    thanks.
  • hardware1
    • Sep 2021
    • 2943
    • N/A
    Re: bios password Lenovo L440
    thanks.
    Here's your Patched file, you will need to read this tread carefully.
    https://www.badcaps.net/forum/showthread.php?t=87588
    all donations are welcome,
    • rachidell
      • Aug 2016
      • 137
      • algeria
      thank you it's working
      • LeonCass78
        • Oct 2022
        • 9
        • Hampshire
        Would someone be able to remove this bios password please
          • 21446
          You can patch it yourself using the available unlocking software in the forum.
          By the way,your backup is shit, read this https://www.badcaps.net/forum/showpo...40&postcount=2
          Originally posted by piernov
          Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
          Please read the rules before posting,you must always include the laptop serial number,amongst the other rules.
          You MUST:
          Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
          • Danmoh
            • Sep 2021
            • 57
            • Kenya
            Lenovo L440 Bios Password
            Serial number R90FM6T6
            Kindly remove the password on the attached bios bin.i have tried autopatcher but my patched file didnt work.Thank you
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1252
              • France
              did you find the solution for that?​
              https://www.badcaps.net/forum/troubl...09#post3312009
              try
              • kamkooltech
                kamkooltech
                • Jun 2019
                • 117
                • nigeria
                lenovo L440
                S/N: R9-0HT3ZX
                help me to unlocked the password or help me to patch the file.
                i have tried to patch the bin file, is not working
                • kamkooltech
                  kamkooltech
                  • Jun 2019
                  • 117
                  • nigeria
                  thank you every one.
                  i later solved it, i make used of post #7 file
                  mind you, what i experienced is.
                  Patiently
                  first boot will takes like 2-3 minutes to display immediately press F1
                  Next press any key or 123 on password then follow the instruction
                  STEP 1: Flash and replace current BIOS with the generated patch file
                  STEP 2: Boot the machine
                  STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                  STEP 4: Enter any character when asked for Supervisor Password
                  STEP 5: Press enter when it shows Hardware ID
                  STEP 6: Press space bar 2x when asked
                  STEP 7: Turn off machine
                  STEP 8: Restore original BIOS
                  STEP 9: Reset BIOS settings to factory default​
                  • 5560BK
                    • Sep 2025
                    • Nepal
                    Supervisor Password in Lenovo L440 How to solved
                    • RMDUiFT
                      Should I buy a Lenovo Thinkpad E495 with bios password?
                      by RMDUiFT
                      Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                      I have a few questions:
                      • If I would buy this laptop and have
                      08-25-2024, 09:00 AM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • baaligoga
                      Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                      by baaligoga
                      Good day, everyone!
                      I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                      I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                      05-20-2023, 09:48 AM
                    • darknwo
                      Bios password Lenovo Legion 16IRX8H
                      by darknwo
                      Hi, can someone help me please with the removal of the bios password of this dump.
                      Someone desoldered the bios chip, tried several "methods" but with no luck, and he gave me the dump to try to search some help.
                      For now he deleted more things and bios password is gone but laptop doesn't show serial, model etc.
                      Also, I updated bios to latest version, when he will write the dump again without password, it should be better to put back the old version that was orignally or doesn't matter? Because from what I've read this laptop has 3 bios chips, don't know if has...
                      10-05-2024, 10:40 AM
