Microsoft Surface laptop 4 UEFI password
  • hoaca388
    replied
    Originally posted by roli1980 View Post
    hi can anyone remove this please ?
    1951
    serial - 024426322557
    What remove ?
  • roli1980
    replied
    1951
    post merged...
  • netboy69
    replied
    Surface Laptop 4
    Model: 1951
    Serial - 024426322557
    Can anyone help me clean this? Many thanks in advance.
  • Rob91
    replied
    I wonder if someone can help, I have a surface laptop 4 model 1951 which i don't have the UEFI password for.
    I would like to get it reset if possible and know I need to provide information and the bios backup. I'm currently having issues getting a bios backup and wonder if anyone can assist, I've checked the guides but there doesn't seem to be specific information for the surface laptop.
  • peste
    replied
    Originally posted by Randy Sitoski View Post
    Hi, Im new to all this and not sure if this is the correct place but im looking for password for my surface laptop 5
    Model 1951
    SN 0F00AAB23303FB
    not sure what else you require.
    Please help
    post the original contents of the bios chip..
  • peste
    commented on 's reply
    post merged..
  • Randy Sitoski
    replied
    Model 1951
    SN 0F00AAB23303FB
    Please help
  • volinakis
    replied
    Originally posted by tataie View Post
    it works perfectly!
    thanks !
    Cu placere!/ you are welcome
  • tataie
    replied
    Originally posted by volinakis View Post
    invalidate IPCVN
    it works perfectly!
    thanks !
  • volinakis
    replied
    Hi!
    I succesfuly removed UEFI pass, now i need to remove SEMM certificate but i don't know how to start
    Please help me
    Thanks!
    invalidate IPCVN
  • tataie
    replied
    Please help to remove bios pass
    Model Surface Laptop 4 1951
    S/N: 042177713557
    Thank you!
    Hi!
    Please help me
    Thanks!
  • peste
    replied
    Originally posted by Bodge_it_and_run View Post
    I have a surface 4 laptop (model 1951) which I cannot get past the UEFI/ BIOS system password as I do not have a record. Cannot change the boot sequence in the UEFI given no password, and cannot access windows as do not have the bitlocker key.
    Would anyone be able to help guide me through what to do - have read various posts about scripts, certificates, BIOS dumps, but really don't have a clue how to do this. Have tried opening and taking out the SSD, but this did not reset the UEFI password. I cannot locate a CMOS style battery, so assume it doesn't have one.
    Have all my data stored on network drive and onedrive, so quite happy to erase the whole thing - if only I could...
    post S/N, full name and model, motherboard model,post the original contents of the bios chip..etc.
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
  • Bodge_it_and_run
    replied
  • tataie
    replied
    S/N: 042177713557
    Thank you!
  • giliy52480@degcos.com
    replied
    Originally posted by minhdigital View Post
    Try
    I tried this but still no disp.
    This surface laptop had a backlight flickering. I put some heat on the edp socket and some capacitors around (I think cold solder occurred) the socket, but after some days the problem came back. Then, immediately after turning it on, the system firmware update appeared, and during the test for the edp connector, whether it was broken or not, the system turned off and finally, when it turned on, the backlight was on, but no disp. When I pressed the F4 key to go to the bios, the display had some horizontal line on the screen with a backlight but no disp (the picture enclosed) and the CPU got warm. This line's place changed after the restart.
  • minhdigital
    replied
    Originally posted by giliy52480@degcos.com View Post
    HI dear,
    Surface laptop 4 1951
    Sn: 036094623057
    First the black screen system update bar showed and wouldn't complete(due to power off the system) , then the system turned off. After that, the blank screen and "backlight on", then the display wouldn't show surface logo, but the CPU got warm. The original bios have been enclosed. Please check the file and give me the proper bios.
    Try
    replied
    HI dear,
    Sn: 036094623057
  • peste
    merged post..
  • nobbie
    replied
    I have a corrupted bios chip after an update.
    If anyone has a dump I would be very grateful.
    Model:
    Microsoft Surface 4 (2021) Model 1950
    Intel Core i5 11th Generation
    512GB SSD
    16GB Ram
    Bios-Chip: W25R256JWPQ
    S/N: 024302314457
    Thank you
  • silvertree
    replied
    I'm about to have a go at downloading the bios file from a Surface laptop 4 (1951), which is password locked at the bios level.
    I'm interested in how you go about changing the bios file.
    I've compared a few of the pairs of files above in HxD, and see that in every one a 3F has been changed to a 3C.
    My question is, how do you know which 3F to change?
    I suspect it is something to do with the serial number of the computer, but I am unable to find the serial number within the Hex file, and wonder what I'm doing wrong.
    (Serial number of computer I'm about to work with is 025136421857)
    I'd appreciate some insight please! Short of that, I might be back in a week or so with a file, for some direct help. 😊
    Keen to understand - Thank you!
