dell la-g717p 3 amber 5 white lights
  • ahmarzo
    • Mar 2015
    • 171
    • india
    i have dell la-g717p the mec1418 ic was heating when i got the laptop and 3v was short.after changing the ic the board is powering on but i got no display and led is blinking in 3 amber 5 white continously.do i have to reprogram the io chip.if so please provide me with the bin file.i have attach the backup of both 8 mb and 16 mb bios.please help
    • 20961
    Re: dell la-g717p 3 amber 5 white lights
    post the laptop model number and service tag
    • ahmarzo
      • Mar 2015
      • 171
      • india
      service tag 7R2JS53.MODEL NO DELL VOSTRO 15 3000
      • lapfix
        • Mar 2020
        • 2731
        • my workshop
        Try , wait a few seconds , it will restart many times
        • hardware1
          • Sep 2021
          • 2932
          • N/A
          as i know, when you change the SIO chip you need to reprogram it if it's programmable.
          so here the 192kb EC file extracted from Dell website for your (Vostro 3590).
          all donations are welcome,
          • q5q
            • Dec 2022
            • 32
            • United Kingdom
            Any updates on this, I have the same 3 Orange 5 White flashes.
            There was a short to ground on 5V rail. I replaced DC/DC switch (it was cracked possibly exploded) and fan capacitor as it was shorted to ground. The short is now fixed however there is still the same LED codes. No obvious signs of something wrong.
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              If you want further help beyond a bios request start a new thread here:
              https://www.badcaps.net/forum/forumdisplay.php?f=23
              Become a Badcaps supporter
              Thanks to all supporters.​
              • Themi
                Dell XPS 13 9310 2 amber 4 white memory failure
                by Themi
                I have this laptop a dell XPS 13 9310
                Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
                I believe this is the spec from using micron tool to decode marking
                Images of the ram
                I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
                Another...
                11-24-2024, 09:06 AM
              • Amirnsrti
                Dell Inspiron 5567 2 amber 6 white error
                by Amirnsrti
                Hi everyone
                I have this Dell Inspiron 5567 laptop that shows 2 amber 6 white error when I try to turn it on it's fan starts to work at very high speed even though I just turned it on and laptop is cold, screen is black but it shows very dim lines for less than a second when I click on power button. I used it like 4 years and I got this error so I didn't used it for last 3 years.
                The error it gives is for motherboard chipset issue.
                I Read some topics that something is wrong with bios but I don't really know how to flash the bios using another bios file. So I really appreciate...
                07-08-2024, 10:40 PM
              • s_henya
                Dell Inspiron 3593 3 amber 1 white
                by s_henya
                Got this in today,
                no signs of life.
                found a broken charging port- after replacing it, the laptop turns on and charges the battery.
                Trying to turn it on, laptop powers up, capslock is on and not responding, no image on the screen. Indicator led is flashing with 3 amber 1 white.
                CPU and GPU are very hot, so laptop has all the required voltages.
                Cmos battery is okay ~2.9v which supposed to be okay.
                Could it be a bios problem?...
                10-14-2024, 03:10 AM
              • nodwas
                Dell g15 alien 2 amber 1 white led flases ?
                by nodwas
                LA-K454P error code 2 amber flashes and 1 white..
                blank screen . Can anyone point me in right Direction to look.
                all power rails correct voltage. no idea. where to go next
                02-22-2024, 01:42 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
