Need Lenovo IdeaPad 3 14ITL05 board NM-D461 Dump
Try again with different BIOS version GCCN33WW
S/N, MTM, Win key edited in
S/N PF3VNZQ7
MTM 81X700EJARβ
Flash both chips 8MB and 16MB; if that doesn't work check for hardware problemAttached FilesPremium supporters get full download access and other benefits.
Your MB is HS45A/HS55A Rev 1.0 NM-D461 ? If yes there is a post in Schematic Requests : https://www.badcaps.net/forum/troubl...98#post1802898Comment
Hi everyone, I have a problem with my laptop, and I'm coming to this great forum to ask for your help.
The laptop isn't displaying an image on the screen; the fan just spins and then stops. The power button LED keeps blinking. I've already backed up the BIOS and other files. I'm hoping you can help me. Thanks!
laptop lenovo ideapad 3 14ITL05
BOARD: HS45A/HS55A Rev 1.0 NM-D461
MO:PF9XB2C26014
MTM: 81X700FXUS
S/N: PF47ZMHRAttached FilesPremium supporters get full download access and other benefits.
Everything you need is in this post https://www.badcaps.net/forum/troubl...62#post1750862Hi everyone, I have a problem with my laptop, and I'm coming to this great forum to ask for your help.
MO:PF9XB2C26014
MTM: 81X700FXUS
S/N: PF47ZMHR
Copy the DMI from your 16MB backup to the new one with a hex editor. If you don`t know how to do that let us know.Comment
I really appreciate the response. I'm a bit of a novice when it comes to editing bin files. Could you possibly help me with how to do it?
search for text "LENV" in your 16Mb file (using a hex editor) or go to adress 422000. Select content from 422000 - 423FFF, there are 8192bytes, and copy (Ctrl+C). Open 16Mb file from post #6 and do the same (select content from 422000 - 423FFF then paste the copied content from your file, Ctrl+P. Save file and write into your bios chipset.
please support this forum
-----------------------------------------------------Comment
Thanks for the help, I followed the instructions, but the problem persists. What else can I do?Comment
Try, DMI inserted
ideapad 3-14ITL05 Laptop - Type 81X7
BIOS ver. GCCN33WW
S/N PF47ZMHR
MTM 81X700FXUS
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
BIOS PASWAD
Hi, Stop spamming and Post the Serial Number (it's required with every request)
> RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - BadcapsComment
I'm troubleshooting a Lenovo IdeaPad 3 14ITL05 that won't boot. Here's the full picture:
Machine info:- Model: Lenovo IdeaPad 3 14ITL05
- MTM: 81X700FGUS
- Serial Number: PF2SH1TX
- Motherboard model/revision: HS45A/HS55A Rev 1.0 - NM-D461.
Original symptom:
Press the power button β LEDs turn on β CPU fan spins for a moment β system shuts off on its own β screen never lights up at any point (no logo, no backlight, nothing).
After a having disconnected the battery, the charger and pressed the power button for 30 secs, the power button LED now blinks at a steady, constant rate when I try to power on.
The fan still spins briefly and stops, same as before. Still no display.
Current test setup:- Only the AC charger is connected β battery is unplugged
- No peripherals attached (no USB drives, no mouse, nothing)
- No external monitor tested yet
- RAM: this model has one module soldered to the board plus a single SO-DIMM slot, which is currently empty β so I can't test with a second stick or reseat anything
- I only have the one charger, so I haven't been able to test with a different power adapter
What I'm trying to figure out:
Does this pattern (steady LED blink + brief fan spin + shutdown, even with battery removed and no peripherals) point more toward a corrupted BIOS/firmware, or toward a hardware fault like the VRM? Has anyone seen this exact blink pattern on a 14ITL05 and knows what it corresponds to?
Appreciate any input before I send it in for motherboard repair.Comment
post the contents of the bios chip even if it is corrupted..Hi all,
- MTM: 81X700FGUS
Original symptom:
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowComment
Hi friend, thanks for the reply.
I found the solution to my problem in another thread on the forum.
The issue was that the RAM soldered to the motherboard was dead.
I had to flash a modified BIOS after running a script to remove the soldered RAM info from it. Now it only uses the one in the second slot.
Thanks for your help.Comment
This specification for the Lenovo IdeaPad IdeaPad 5 14ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 14ITL05 boardview and IdeaPad 5 14ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:10 AM
This specification for the Lenovo IdeaPad Flex 5 14ITL05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 14ITL05 boardview and Flex 5 14ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:30 AM
by samirinfoLenovo Yoga slim 7 14ITL05 Bios dump/Password remove
Can I remove my bios dump?
SN: LR0EJB0E
Factory ID: CS20
Lenovo Yoga 7 14ITL05
Board: DALSBMBAG0 REV : G
HELP PLZ
post moved..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.....-
Channel: BIOS Requests ONLY!
This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:20 AM
- Loading...
