Lenovo Edge E531 boot option vanished in bios
  • Minime_2003
    • Sep 2022
    • 5
    • Sweden
    Hi i have a Lenovo Edge E531 with a CPU 2.2GHz (Intel core i7-3632QM) with firmware HEET35WW (1.16) upgraded with Win 10 OS.
    Have a issue that my boot menu vanished in bios.
    When trying to boot system, screen is just black.
    If trying to press F12 at startup the screen is black and all one can see is a blue marker blinking up in the left corner of the screen.
    I have tried loading setup default in BIOS, this did not help.
    I have tried removing, battery and bios battery and connected both batterys back and then booting system again. but this did not resolve the issue.
    Read somewhere that this could somethimes happen with Win 10 removing something from Bios/UEFI?
    Solution as i understand was to try to reflash the bios, but as i cant get it to boot on a bootable USB-stick/DVD and not booting the harddive its not possible the ordenary way.
    So i figured i get my self a CH341A SPI-Programmer.
    Problem is that i dont know what chip i should try to connect it to on the motherboard or where it located.
    Found a picture of showing a chip, that i guess is the Bios chip?
    But as the dumpes on this page have two or more bin files i am wondring if there are more chips top flash and what files i should flash to what chip?
    Please could some one give me some directions and tell me if this is the correct Bios chip and what file to flash to this chip?
    This is the picture i found that was to tell where the bios chip is located... (Found it at https://www.all****)
    • 20918
    Re: Lenovo Edge E531 boot option vanished in bios
    This is the picture i found that was to tell where the bios chip is located... (Found it at https://www.alls******)
    That isn`t the bios chip, it is where the password is stored. There could be 1 or 2 bios chips ,not sure.Look for 25Q32 ,25Q64 etched on top. Make multiple backups and check them to make sure each backup is the same and has some code in them,not all FF`s ,then post your backups here in a zip or rar attachment
    https://www.badcaps.net/forum/showpo...40&postcount=2
    • Minime_2003
      • Sep 2022
      • 5
      • Sweden
      Thank you, i will look in to that and see what i can find.
      • Minime_2003
        • Sep 2022
        • 5
        • Sweden
        Hi so i have found a chip on top of the board near by the CPU.
        Marked "25Q64F VSIG" Dumped two files and this is what i got.
        • Minime_2003
          • Sep 2022
          • 5
          • Sweden
          So i managed to figure out that the "25Q64F" chip seems to be some kind of backup, when reading this file its the same size as the "*PCH.bin" file.
          Tried flashing this and assabled the laptop, but when checking the bios it was not updated.
          Looked at the motherboard schematics and saw that the chip i found was on U5 on the motherboard. There was supposed to be a "25Q32" chip next to it on U6.
          But this was a "cFeon" chip? According to the schematics this was to be the bios chip.
          So i dumped this chip and flashed this with the "*main.bin" file as the dumpfile that i made was the same size.
          Assabled the laptop again and booted it and entered the bios.
          Finally The bios was updated and also fixed the issue with the missing startup option in bios menu...Sweet!
          Thanks for all the help and great guides.
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • q2v5
            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
            by q2v5
            Lenovo T480s
            Model 20L8-S3TE00
            Board ET481-U10
            Chip MX25L12873F
            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
            08-15-2024, 10:40 PM
          • Neddsme
            Bios partially corrupted somehow and now warm boot doesn't work which is critical
            by Neddsme
            Hie.
            I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
            Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
            I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
            I managed to run Windows troubleshooting and...
            02-04-2022, 05:57 AM
          • Max029
            Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
            by Max029
            I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
            I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
            TY,
            08-18-2024, 08:28 PM
          • futadmytro
            Asus g713qm-es94 stuck on boot bios problem
            by futadmytro
            sn^M4NRKD02753616E
            MB- g533-6050a3250201-MB-A03
            Stuck on boot after ROG logo, did not enter to bios
            In flash bios , laprop boot but have video issue
            orig bios...
            06-25-2025, 08:07 AM
