Surface Go 1943 bios
Need Help with Surface 1943 stuck on logo serial QTFMZAB014054381 or 022701213766Attached FilesPremium supporters get full download access and other benefits.
Surface Go 1943 MDM blocked
Please remove MDM
SERIAL Number: 030080310266
Motherboard model number is DA0Z91MBAE0 REV:E
Hi, try this file.Attached FilesPremium supporters get full download access and other benefits.
HI TRYAttached FilesPremium supporters get full download access and other benefits.
Pls help and with these files same issues, mdm blocked, i tryied compare but something goes wrong. Thanks
W25Q128FW1.8V@SOIC8 - Surface 1943 MDM Second - S/N: 030752410266
W25Q128FW1.8V@SOIC8 - Surface 1943 MDM Third - S/N: 030349210266
MICROSOFT SURFACE 1943 backup - S/N: 023714410866Attached FilesPremium supporters get full download access and other benefits.
Try these mods, and if they work, you can compare again.Pls help and with these files same issues, mdm blocked, i tryied compare but something goes wrong. Thanks
Enjoy.Attached FilesPremium supporters get full download access and other benefits.
by chriswfrye21Hi everyone,
Iβm working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
This is not a PowerβOn Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
Iβm posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
Model: HP 255R 15.6 inch G10 Notebook PC SK...-
Channel: BIOS Requests ONLY!
by Olegst44Hello everyone,
I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
Device Information:
- Model: Acer Aspire 3 A315-22G
- Motherboard: NB8607G02-MB (Compal LA-J761P)
- BIOS Chip: Winbond W25Q64 (8MB)
- Serial: NXHE7ER00X95002B784S00
Problem:
- BIOS is password protected (Supervisor Password)
- Boot from USB is disabled in BIOS
- After 3 wrong password attempts, system shows Unlock Key Hint
- I have RT809H programmer available
What I need:
1. Clean BIOS dump (password...-
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by vic6688Hello everyone,
I would like to ask for your help with my ASUS desktop.
Model:
ASUS ExpertCenter D700SA
BIOS:
AMI Aptio V
BIOS Flash:
Winbond W25Q128JV (16MB)
I forgot the BIOS Administrator password.
I have already read and verified the complete BIOS dump using a CH341A programmer, and I have attached the original 16MB BIOS dump.
If possible, I would prefer to recover or identify the current BIOS password so that I can continue using the original BIOS without reflashing.
If...-
- Loading...
