Dell Latitude 5420 Bios Password 8FC8
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1356
    • France
    #781
    Originally posted by sLs112
    ST: 56K51J3
    Thank you.
    try
    • Andersfriden
      • Aug 2024
      • 5
      • France
      #782
      Hello
      I'm a newbie here. Need help to remove BIOS admin password of the laptop I just bought. S/N: H7PM6G3-8FC8.
      I've been through the posts, and it seems the bios needs to be flashed with some BIN file. Is there a step-by-step guide to make sure it will work?
      thanks in advance
      • Andersfriden
        • Aug 2024
        • 5
        • France
        #783
        Originally posted by Andersfriden
        Hello
        thanks in advance
        I've tried the methods explained in the guide (https://www.badcaps.net/forum/showthread.php?t=103526), but haven't succeeded in removing the password. The removal password generated on https://www.bios-pw.org is not working.
        I still need your help...
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          #784
          can you gave me the motherboard model? ingrave in the board
          • Andersfriden
            • Aug 2024
            • 5
            • France
            #785
            I've found these 2 engraved inscryptions on the motherboard, does this help?
            • rex98
              • Feb 2023
              • 1297
              • Mandaue CEBU, Philippines
              #786
              upload the bios dump.
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                #787
                Please do follow the rules post your backup bin and also the photo must be typed
                Please follow this format
                issue:
                Model:
                Serial Number:
                Motherboard Code:
                Post your backup bin even its corrupted​
                • kyo84120
                  • Sep 2024
                  • 4
                  • France
                  #788
                  hi everyone i got a password issue with my laptop dell latitude 5410
                  ST: DBLL373-8FC8
                  can anyone help me plz
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    #789
                    ST: DBLL373-8FC8
                    issue:
                    Model:
                    Serial Number:
                    Motherboard Code:
                    • kyo84120
                      • Sep 2024
                      • 4
                      • France
                      #790
                      issue:
                      Model:
                      Serial Number:
                      Motherboard Code:
                      Ok so
                      the issue is a bios password forgotten
                      model: latitude 5410
                      serial number DBLL373-8FC8
                      motherboard code : i don't know
                      backup I don't know
                      is it good ?
                      • kalilinux25
                        • Mar 2018
                        • 2093
                        • ZAMBOANGA SIBUGAY
                        #791
                        Ok so
                        backup I don't know
                        is it good ?
                        you must use a spi chip programmer like CH431A , without that you cant create a backup or even flash through the chip on the board.
                        • kyo84120
                          • Sep 2024
                          • 4
                          • France
                          #792
                          have i another way to do it cause i'm a newbee i don'n know how to use a spi chip programmer
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12423
                            #793
                            https://www.youtube.com/results?search_query=CH341A
                            It's the 21st century now.
                            • wo5102586
                              • Jan 2024
                              • 26
                              • IRELAND
                              #794
                              Originally posted by hoaca388
                              Password removed.
                              hello sir thank you help me a lot.
                              the password in the bios had been removed.
                              but when I re-installed a new win10 and connected with internet for a while I saw a message shows up.
                              I have checked online and I thought It due to a option in bios called ‘Absolute'.
                              I found it can't be changed. Could you help me please?
                              • volinakis
                                • Jan 2021
                                • 2875
                                • N/A
                                #795
                                try. in addition of what you did 1st time, see if you permanently disable Absolute. if not, load setup defaults and you can disable Absolute. Also remove CMOS battery.
                                • wo5102586
                                  • Jan 2024
                                  • 26
                                  • IRELAND
                                  #796
                                  thank you soooo much sir !!!!
                                  • volinakis
                                    • Jan 2021
                                    • 2875
                                    • N/A
                                    #797
                                    you are welcome
                                    • sLs112
                                      • Nov 2022
                                      • 28
                                      • United Kingdom
                                      #798
                                      Hi. Please guys, can you help me to unlock bios password?
                                      Dell Latitude 5420
                                      ST: 56K51J3
                                      Mb: LA-K491P Rev: 3.0 A02
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12423
                                      #799
                                      Dell Latitude 5420
                                      ST: 56K51J3
                                      Password removed.
                                      • sLs112
                                        • Nov 2022
                                        • 28
                                        • United Kingdom
                                        #800
                                        Password removed.
                                        Thank you so much! Your a star.
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                          DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                          09-07-2024, 06:31 AM
                                          09-07-2024, 03:40 AM
