Dell Latitude 5420 Bios Password 8FC8
  • Zibbo
    • Mar 2017
    • 203
    • Zimbabwe
    #41
    Re: Dell Latitude 5420 Bios Password 8FC8
    Originally posted by volinakis
    try. 1st screen press F2, disable Absolute, save (Apply), restart. 2nd time write service tag, save, restart, then press Alt+L to exit Manufacturing. For me worked this way.
    Worked! Thank you very much!
    • goool-007
      • Oct 2022
      • 6
      • France
      #42
      Hi everyone, can someone please help unlock this
      Service TAG: G81JGK3
      Bios version: 1.17.2
      G81JGK3-8FC8
      Laptop: Dell Latitude 5420
      • hoaca388
        Badcaps
        • Jan 2022
        • 11917
        #43
        G81JGK3-8FC8
        You have read chip bios failure. File is corrupted.
        Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------
        • goool-007
          • Oct 2022
          • 6
          • France
          #44
          what should I do?
            • 21219
            what should I do?
            What model is your programmer ? ,a CH341A (and what software version) or EZP**** , and are you using a clip ,a pogo pin adapter or have you desoldered the chip
            • goool-007
              • Oct 2022
              • 6
              • France
              #46
              i use As Programmer, because i found SPI (WINBOND W25R256JV) only in this programmer. i use a clip.
                • 21219
                The chip is WSON 8x6 ,the clips only work with SOP8 chips. You will damage the chip using the clip. Solder wires to the solder blobs or gold pads.Your other options are to buy a WSON pogo adapter or desolder the chip and solder it on an adapter board.
                • jetblue
                  • Jul 2018
                  • 17
                  • usa
                  #48
                  i also have a password locked 5420. can someone please unlock it for me?
                  • hardware1
                    • Sep 2021
                    • 2942
                    • N/A
                    #49
                    Here's your unlocked file, try it and let me know.
                    all donations are welcome,
                    • jetblue
                      • Jul 2018
                      • 17
                      • usa
                      #50
                      thanks,it worked! freaked me out when it asked for a service tag but once i put it in all was fine.
                      • MuhendisBey
                        • Nov 2022
                        • 13
                        • Türkiye
                        #51
                        I lost this bios password and I need to login. can you remove the password for me?
                        • tktrom
                          • Jul 2022
                          • 79
                          • Bolivia
                          #52
                          good afternoon, I have a dell latitude 5420 with locked bios and computrace
                          Could you help me
                          Thank you
                          • hardware1
                            • Sep 2021
                            • 2942
                            • N/A
                            #53
                            Could you help me
                            Thank you
                            Here's your Unlocked file, try it and let me know.
                            • tktrom
                              • Jul 2022
                              • 79
                              • Bolivia
                              #54
                              Thank you very much, the bios is already unlocked but absolute is shaded
                              • volinakis
                                • Jan 2021
                                • 2752
                                • N/A
                                #55
                                try
                                • volinakis
                                  • Jan 2021
                                  • 2752
                                  • N/A
                                  #56
                                  try. 1st boot load factory defaults and disable absolute, 2nd boot write service tag and 3rd boot exit factory mode (ALt+F -is written on screen)
                                  • tktrom
                                    • Jul 2022
                                    • 79
                                    • Bolivia
                                    #57
                                    Thank you very much but the computrace is still activated
                                    • Ali5914
                                      • Dec 2020
                                      • 48
                                      • India
                                      #58
                                      Check this out... Please update...
                                      • volinakis
                                        • Jan 2021
                                        • 2752
                                        • N/A
                                        #59
                                        try this one
                                        • tktrom
                                          • Jul 2022
                                          • 79
                                          • Bolivia
                                          #60
                                          good afternoon, this file is with administrator password
                                          Thank you
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-07-2024, 06:31 AM
                                            09-07-2024, 03:40 AM
