Dell Latitude 5420 Bios Password 8FC8
  • mandrake87
    • Jun 2022
    • 70
    • argentina
    #381
    Re: Dell Latitude 5420 Bios Password 8FC8
    Originally posted by devp62
    Hi Can any one pls help and remove admin password dell latitude 5420 11th gen
    GDF40 LA-K491p mobo st 5ZB8RQ3
    prove
    • devp62
      • Dec 2014
      • 56
      • uk
      #382
      It works thanks
      • devp62
        • Dec 2014
        • 56
        • uk
        #383
        GDF40 LA-K491p mobo st 4TZ44M3
        • volinakis
          • Jan 2021
          • 2872
          • N/A
          #384
          1st boot, press F2, write service tag, disable Absolute, Apply changes, restart. 2nd boot press Alt+F to exit manufacturing mode.
          • devp62
            • Dec 2014
            • 56
            • uk
            #385
            hi volinakis, this does not work, the laptop boots and fan on full speed , keyboard back light is on power button is on battery led is on but no other visuals and no flash codes. the original bios dump works but locked.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12243
              #386
              hi volinakis, this does not work, the laptop boots and fan on full speed , keyboard back light is on power button is on battery led is on but no other visuals and no flash codes. The original bios dump works but locked.
              ddddd
              ​https://www.badcaps.net/donate
              • devp62
                • Dec 2014
                • 56
                • uk
                #387
                hi same result but now have a caps lock led on all the time and fan at full speed still, did a emc reset by holding power button for 30 secs and battery led flashed and reboot but still same. original file works still. was this done with the original file or repaired from volinakis file? just out of curiosity. Thanks
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12243
                  #388
                  From original.
                  • komarika
                    • Sep 2023
                    • HYDERABAD
                    #389
                    Originally posted by skazide
                    good work thank you
                    hi how you unlocked... pls let me know bro
                    • volinakis
                      • Jan 2021
                      • 2872
                      • N/A
                      #390
                      let it run for 2 minutes, it will restart several time with no display. Don't forget to REMOVE CMOS BATTERY.
                      • ordinateur
                        • Mar 2020
                        • 84
                        • Monaco
                        #391
                        Dell Latitude 5420 Bios Password ST suffix 0001
                        Hello all
                        First of all, I am sorry if I could have posted on another thread, but I searched the whole forums and I didn't saw any other thread with this model suffix 0001.
                        As per title I have this DELL Latitude 5420 with Service Tag #2CMH7G3-0001 with password. Wanted to remove it but I really don't know if any of these chips should I read or another on the back side of the Motherboard.
                        These 2 possible chips are to be seen as soon as back cover is removed.
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria πŸ‡§πŸ‡¬
                          #392
                          Re: Dell Latitude 5420 Bios Password ST suffix 0001
                          Originally posted by ordinateur
                          Hello all
                          Dump the chip (as far as I recall must be 25RH256CXIQ) above the DIMM slot, next to the processor labeled as UC2.
                          Become a Badcaps supporter
                          Thanks to all supporters.​
                          • ordinateur
                            • Mar 2020
                            • 84
                            • Monaco
                            #393
                            Here it is, thanks very much
                            It is 32MB in size and I desoldered and inserted directly into RT809H to read the dump
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria πŸ‡§πŸ‡¬
                              #394
                              Be careful with the programming - use verification, erase the chip before flashing the unlocked dump.
                              At first boot press F2, write service tag, disable Absolute, save (apply changes) and restart. At the second boot press Alt+F to exit manufacturing mode. Laptop will restart several times, be patient.
                              • gsm4all
                                • Sep 2020
                                • 40
                                • Slovakia
                                #395
                                hello, if you can unlock my dump, thanks
                                802D6M3-8FC8
                                ServiceTag: 802D6M3
                                EX: 17418233019
                                Board:
                                GDF40 LA-K491P
                                Rev: 2.0(A01)
                                2021-04-28
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria πŸ‡§πŸ‡¬
                                  #396
                                  802D6M3-8FC8
                                  Read the rules before posting:
                                  • gsm4all
                                    • Sep 2020
                                    • 40
                                    • Slovakia
                                    #397
                                    ServiceTag: 802D6M3
                                    • volinakis
                                      • Jan 2021
                                      • 2872
                                      • N/A
                                      #398
                                      ServiceTag: 802D6M3
                                      • DexterHolland
                                        • Oct 2023
                                        • EspaΓ±a
                                        #399
                                        I have a similar problem with bios 8FC8, but I can't access the SO so I can't extract BIN file. My father-in-law gave me the laptop locked with no win10 pwd and I want to boot from USB to format it but there is no way to do anything with the laptop :S
                                        Should I purchase the bios pwd from some random indian? Is there another way to get the bios pwd?
                                        Thanks in advance.
                                        Sorry, if needed Service Tag: 8YXJ163
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria πŸ‡§πŸ‡¬
                                          #400
                                          Thanks in advance.
                                          BIOS guides, methods, resources and tools
                                          https://www.badcaps.net/forum/showthread.php?t=103526
                                          Password removal by laptop brand
                                          https://www.badcaps.net/forum/showth...42#post1108842
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                            11-02-2024, 04:19 AM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-07-2024, 06:31 AM
                                            09-07-2024, 03:40 AM
