How to use CH341A to program ENE io chip or startup chips
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys
    I've seen that it's possible to program the ENE chips using the CH341A programmer, one of my buddies was about to send me information how to do it but I lost his contacts…
    I have a gaming laptop with physical burnt ENE CHIP , the programmable one , can someone please guide me or send me information on how to do it .
    Thank you , I believe this will assist others
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • pengamat_hebat
    Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
    by pengamat_hebat
    I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
    Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
    However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
    I also tried applying 3.3V to pin 3, but it still didn't work.
    I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
    03-25-2025, 04:13 AM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • intelg
    HP Elitedesk 800 G6 lost BIOS admin password
    by intelg
    Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
    Here is the hardware identification specs:
    HP EliteDesk 800 G6 Desktop Mini PC
    Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
    BIOS ver S21 Ver. 02.05.01 01/05/2021
    Born on date: 07/26/2021
    SN MXL11841GN
    SKU 3X8V9UCHABA
    UUID 8116E79EF6FFE94DB0B98A3188270C5C
    SYSTEM BOARD ID 8710
    SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
    11-03-2023, 02:05 AM
