latitude 5420 board LA-k491P bios problem.
  • peste
    • Dec 2016
    • 12959
    • ROMANIA
    #301
    Originally posted by saudi_ma
    I have a Dell Latitude 5420 (tested without HDD) and I’m running a diagnostic tool such as Aiken Workbench. The problem is that the tool detects the onboard LAN card, but it shows the message:
    "no working driver for it"
    and the test result is NO Driver.
    Interestingly, when I install Windows, the LAN card works perfectly fine, which confirms that the hardware itself is okay. I have tried multiple cables and diagnostic environments, but the result is the same.
    For comparison, I have a BIOS dump from a working unit and another from the problematic unit. The file sizes are identical. I suspect the issue might be related to a missing or corrupted PXE/UEFI network driver module in the firmware.
    My questions:
    • Has anyone experienced this issue before?
    • What are the recommended steps to add the proper LAN driver to a diagnostic/WinPE environment, or to safely repair the firmware?
    • If no solution can be found, I would appreciate it if any expert who knows how to fix this fault could contact me privately to suggest the right approach.
    Thank you in advance for your help.
    post S/T, full name and model, motherboard model, ,etc.
    post the contents of the bios chip even if it is corrupted..
    • devp62
      • 56
      #302
      Hi Hope someone can help me , I have a latitude 5420 that came in with a damaged chip as someone has has a go at repairing the laptop.
      I have replaced the chip and reprogramed it but now the machine come to life but gets stuck at the dell logo and get the 3 amber x6 white led flash, the old chip had a hole init so cant read any thing off it.
      Can some on help pls
      St: 6RKDJQ3
      Latitude 5420
      Motherboard model :-GDF-40 LA-491P Rev 2.0 ( A01 )
      • Laboratorio JG
        • Apr 2025
        • 24
        • Colombia
        #303
        Originally posted by Laboratorio JG
        HI, COULD YOU HELP ME WITH THIS BIOS? IT SHOWS A TPM ERROR AND HAS AN ADMINISTRATOR KEY? CAN YOU HELP ME PLEASE?
        BOARD MODEL: GDF40 LA-K491P REV 2.0(A01)
        2020-11-16
        DELL MODEL: LATITUDE 5420
        ST: 4X036D3
        Could someone please help me, I've tried other bios and it doesn't work, could you help me with the one I sent please?
        • Omar Villalba
          Omar V23
          • Jun 2025
          • 6
          • Paraguay
          #304
          Originally posted by bachir2004
          Re: latitude 5420 bord LA-k491P bios problem.
          ok.see pm.
          I'm having the following issue: I tested this BIOS and the system boots up without any problem, but when the operating system starts, the BIOS gets updated and the computer stops turning on, only showing the message "BIOS CORRUPTED."
          Has anyone else experienced this issue?
          DELL LATITUDE 5420
          GDF40 LA-K491P
          Rev: 2.0 (A01)
          PWB: 2FM7C
          ST: F4243F3
          I'm attaching the original BIOS.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11891
            #305
            DELL LATITUDE 5420
            GDF40 LA-K491P
            Rev: 2.0 (A01)
            PWB: 2FM7C
            ST: F4243F3
            Latitude 5420
            Service Tag: F4243F3
            • chelsea1155
              • 28
              • vietnam
              #306
              PLEASE HELP ME FIX THE BIOS FILE
              Dell latitude 5420
              st: BHJP6J3
              LA-K491P
              • hoaca388
                Badcaps
                • Jan 2022
                • 11891
                #307
                Dell latitude 5420
                st: BHJP6J3
                LA-K491P
                Latitude 5420
                Service Tag: BHJP6J3
                • TripTop
                  Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                  by TripTop
                  Hi
                  i have dell latitude E7270 with following symptoms:
                  - takes long time to restart.
                  - sometimes powers on and then off
                  - sometimes while working it just dies,
                  From googling online bios clean could possible resolve this?
                  i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                  As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                  I reinstall...
                  09-09-2024, 02:05 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • gizaha
                  by gizaha
                  02-13-2024, 07:18 AM
                  DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                  This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                  09-07-2024, 06:31 AM
                  09-07-2024, 03:40 AM
