On Board Ram Disable via Bios Editing
  • peste
    • Dec 2016
    • 13209
    • ROMANIA
    #101
    Re: On Board Ram Disable via Bios Editing
    Originally posted by guyandpit
    hi can you disable onboard ram, Im having bsod memory management error when installing windows. see attached original bios. this asus zephyrus m16 gu603-he. thank you and more power!
    try
    • guyandpit
      • Oct 2021
      • 82
      • Philippines
      #102
      Originally posted by peste
      try
      hi, i tried but i cant erase my existing rom, im using ch341a(flash&software) and my bios ic W25R128JVSIQ. any suggestion to erase the rom? thank you
      • peste
        • Dec 2016
        • 13209
        • ROMANIA
        #103
        make a copy of the original bios before deleting or reading..use this..
        https://www.badcaps.net/forum/showpo...6&postcount=10
        https://www.badcaps.net/forum/showpo...04&postcount=7
        • guyandpit
          • Oct 2021
          • 82
          • Philippines
          #104
          I tried to flash the orig and write the new one, keyboard light only, i reflash back to original. Any thought the modified bios didn't work? Thank you
          Originally posted by Aditya11ttt
          Post Hp | Dell | Asus | Lenovo
          on board Ram Bios we try to disable via bios edit.
          Lenovo s340-14IPA
          • Qwerrs68
            • Sep 2023
            Hello. Can you disable onboard RAM? Lenovo ideapad 3 15are05
            • peste
              • Dec 2016
              • 13209
              • ROMANIA
              #106
              post the original bios of the laptop
              • Alegoff
                • Oct 2023
                • 10
                • Ukraine
                #107
                Can you please help disable on board ram for LENOVO IDEAPAD 3 15ARE05 NM-C861
                SN: PF2BL2H8
                Straps do not help to transfer the motherboard in DIMM only
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #108
                  You must post the serial number.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                  • Alegoff
                    • Oct 2023
                    • 10
                    • Ukraine
                    #109
                    Sorry
                    I edited the post
                    Thanks for the instruction
                    • peste
                      • Dec 2016
                      • 13209
                      • ROMANIA
                      #110
                      Sorry
                      I edited the post
                      try..
                      • Alegoff
                        • Oct 2023
                        • 10
                        • Ukraine
                        #111
                        Hello
                        Thanks for the help, but unfortunately for some reason these modified bios do not help
                        Static consumption 0.4A
                        Although with the bios distributed on the network, which seems to be for this platform, there is a launch and everything seems to work (except for the built-in microphone and the output to the headset)
                        As it turned out, the reason for this is that this bios is designed for a different NM-C811 platform, not NM-C861
                        And what is wrong in this situation is not clear?
                        Hardware change with straps and modified bios did not help (
                        • Suresh8522
                          • Sep 2023
                          • India
                          #112
                          Lenovo IdeaPad pad 330s ast MB v10 onboard ram disable bios file ... I need it's available
                          • Marcus3235
                            • Jan 2024
                            • India
                            #113
                            Please, I Need On-Board Ram Disabled Bios For Lenovo V15-ADA (82C7), Ryzen 5 3500U Model, SN: PF2PGAL0
                            • thilanga
                              • Jul 2017
                              • 3
                              • srilanka
                              #114
                              Can you please help disable on board ram for ASUS X409JA
                              • Claudiomfa
                                • Nov 2015
                                • 455
                                • Portugal
                                #115
                                try and report
                                • Marcus3235
                                  Marcus3235 commented
                                  Editing a comment
                                  Its giving secure flash error
                                • Claudiomfa
                                  Claudiomfa commented
                                  Editing a comment
                                  You have to dessolder bios chip from motherboard and write this file with external programmer. Not flash with official software
                              • Claudiomfa
                                • Nov 2015
                                • 455
                                • Portugal
                                #116
                                try and report
                                • thilanga
                                  thilanga commented
                                  Editing a comment
                                  thanks for the help on board ram disable
                              • tumishima
                                • Jan 2024
                                • 4
                                • Scotland
                                #117
                                Hello. Can you disable onboard RAM? Asusrog Zephyrus G14 2020 GA401IV 221_BIOS_Update​
                                  SMDFlea commented
                                  Editing a comment
                                  Why post the bios update,don`t you have a bios backup ?
                              • tumishima
                                • Jan 2024
                                • 4
                                • Scotland
                                #118
                                I thought i had to post the current update to get it edited. Sorry if i got that wrong. It'll be a great help to get it edited though
                                  SMDFlea commented
                                  Editing a comment
                                  What about the DMI in your backup, the serial number,windows key.You will lose DMI by flashing another bios.The DMI can be transferred (if you post your backup) to the new bios no problem,then edited to disable ram.
                              • tumishima
                                • Jan 2024
                                • 4
                                • Scotland
                                #119
                                I'm at my wits end. How do i backup the bios?
                              • lauri61
                                • Jul 2015
                                • 5
                                • italia
                                #120
                                Can you please help me to disable built-in ram for ACER aspire a315-21
                              • grimacelord
                                by grimacelord
                                07-10-2025, 02:52 PM
                              • DynaxSC
                                by DynaxSC
                                11-17-2023, 10:56 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • throwaway327
                                by throwaway327
                                Model No: RC72LA
                                Serial No: SBNVKD001014459
                                06-18-2025, 05:52 PM
