On Board Ram Disable via Bios Editing
Every donation made will go towards server fees and maintenance costs. -
Re: On Board Ram Disable via Bios Editing
https://www.badcaps.net/forum/showpo...6&postcount=10
https://www.badcaps.net/forum/showpo...04&postcount=7Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
make a copy of the original bios before deleting or reading..use this..
Lenovo s340-14IPAComment
Hello. Can you disable onboard RAM? Lenovo ideapad 3 15are05Attached FilesComment
Can you please help disable on board ram for LENOVO IDEAPAD 3 15ARE05 NM-C861
SN: PF2BL2H8
Straps do not help to transfer the motherboard in DIMM onlyAttached FilesLast edited by Alegoff; 10-28-2023, 02:56 PM.Comment
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
You must post the serial number.
I edited the post
Thanks for the instructionComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hello
Thanks for the help, but unfortunately for some reason these modified bios do not help
Static consumption 0.4A
Although with the bios distributed on the network, which seems to be for this platform, there is a launch and everything seems to work (except for the built-in microphone and the output to the headset)
As it turned out, the reason for this is that this bios is designed for a different NM-C811 platform, not NM-C861
And what is wrong in this situation is not clear?
Hardware change with straps and modified bios did not help (Comment
Please, I Need On-Board Ram Disabled Bios For Lenovo V15-ADA (82C7), Ryzen 5 3500U Model, SN: PF2PGAL0Attached FilesLast edited by Marcus3235; 01-01-2024, 09:03 PM.Comment
Can you please help disable on board ram for ASUS X409JAAttached FilesComment
try and reportAttached FilesComment
Hello. Can you disable onboard RAM? Asusrog Zephyrus G14 2020 GA401IV 221_BIOS_UpdateAttached FilesComment
I thought i had to post the current update to get it edited. Sorry if i got that wrong. It'll be a great help to get it edited thoughLast edited by tumishima; 01-10-2024, 09:18 AM.Comment
Can you please help me to disable built-in ram for ACER aspire a315-21Comment
Post the laptop serial number
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
Channel: BIOS Requests ONLY!
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Assuming...7 Photos - Loading...
