Medion Akoya e2293 md61144 bios dump needed
  • kew1701
    • Nov 2013
    • 40
    • Poland
    Hi,i bought this convertible N5000 pentium silver ,voltages 1.2v 3.3v 5v and 8.5v are present,but no picture on screen,no power led just charging works,so m only solution is to try other bios dump...i tried almost everything so this is weird for me,nothing heats no shorts on mainboard...please help...
    • 20781
    Re: Medion Akoya e2293 md61144 bios dump needed
    post your backup and the laptop serial number
    • kew1701
      • Nov 2013
      • 40
      • Poland
      https://gofile.io/d/v31BVt
      I have 3 dumps,all are identical...
      Tried:
      HTML Code:
      https://www.youtube.com/watch?v=UiPXewRPf-U&t=603s
      nothing
        • 20781
        try this one.Virgin bios extracted from update.
        • kew1701
          • Nov 2013
          • 40
          • Poland
          Tried,still the same....thanks for U'r effort SMDFlea,i was not expect anyone will post it!!But i assume it is something worse bc's power led is blank,it only flashes once when i hold pwr btn for 15sec(reset maybe),charging works and i get all batt stages(red,orange,green)....
          • kew1701
            • Nov 2013
            • 40
            • Poland
            Just to inform,as there was no short,and nothing suspicious,i reflowed bga cpu,and all worked(including bios SMDFlea posted)...
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
            • vinaypundith
              Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
              by vinaypundith
              I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
              So, I'm looking for a BIOS dump for this machine - a 16MB one....
              08-03-2024, 12:32 PM
            • James Maxwell
              HP DM1-4000er Bios Dump needed
              by James Maxwell
              I badly need bios dump for HP DM1-4000er,
              Model: HP DM1-4000er
              Motherboard: DA0NM9MB6D0 REV.D
              Product: QJ490EA#ACB
              Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
              10-28-2024, 05:38 PM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
