HP Omen 17 AN113NS BIOS
    Need Bios for HP Omen 17 AN113NS BIOS
    Motherboard: dag3bembcd0 Rev D
    It is clear that the bios is more than corrupt. Let's see if you can get the necessary data. Thank you very much in advance.
    Re: HP Omen 17 AN113NS BIOS
    What youve posted is firmware for the displayport,usb-c or something else. It isn`t the bios, which should be 8,16 or 32MB .Look for a chip with 25Q64,25Q128 or similar
      Forgive me for my ignorance but I don't see another chip that could be the bios. This one has the following identification number:
      25q80dvsig
      I don't know if I could send a photo of the plate to confirm it.
        It was indeed my ignorance.
        here is the chip
        GD25b127dsig.
        A thousand pardons.
          OMEN by HP - 17-an113ns
          Serial number : 5CD92661JK
          Become a Badcaps supporter
          Thanks to all supporters.
            Thank you.
            One question: What do I do with the serial number?
            I have to put it somewhere or the laptop asks me when it starts up.
              Thank you.
              Don't worry about it. Just hit power button.
                It still doesn't work. Some other bios since with the ME Analyzer program it gives an error and possible data corruption
                  If it's the serial number on your device then look for other hardware causes. The bios file is brand new and it's ok.
                    Ok.Thanks
                      Ok.Thanks
                      First sorry..., don't speak english.
                      Tolatara te puedes poner en contacto conmigo? Tengo el mismo equipo y creo que el mismo problema. ¿lo resolviste?
                        Use google translator
                          Sorry x 1000
                          I have the same computer and it doesn't start, it doesn't do anything, no noise, no fans, no lights, nothing. The power adapter and battery are ok.
                          Options... Corrupt BIOS or broken motherboard.
                          That BIOS that puts a partner above ".bin", how can I force my laptop to read it? Right now I have everything lost.
                            Sorry x 1000
                            first check if you have voltages on the board 19v, 3.3v, 5v, etc
                              I Agree. I'll try it.
                                Finally on a 3.3 volt line a short was discovered. A capacitor was not working and the KBC had burned out. Condenser and KBC have been replaced and the computer is working. Thank you all.
