Surface Pro 6 - Physically Broken Bios Chip
  • Evostar
    • Jun 2022
    • 5
    Hi Everyone and thank you for having me!
    I recently own a 2nd hand i5/8GB/256GB Black Edition Surface Pro 6, which was an upgrade from my Pro 4 which had display issues.
    Issues arose with the Surface 6 when I got home and went to do my usual clean and custom Wim image of W11Home I debloated.
    fire up the recovery usb > cmd > diskpart > see disk 0 > clean..... (worst mistake this time around)
    Well little did I know I can't actually write to the efi partition anymore due to a setting in the uefi. no worries ill disable it! So I restart enter the uefi procedure and I'm in!!!,,,.... wait! what!!! password?!... (I hadn't seen the before due to my Surface 4 not having one..)
    Any way I found a way to bypass the efi by using a FFU DISM backup of a fresh install on my Surface 4 and then Applying it to my Surface 6 from the USB recovery, all goes well and I go on my way happy for a few days...
    To be honest though, that password is just bugging me... I just want it gone, is I go down the rabbit hole of looking into flashing the bios to remove the password lockout.
    So I heat her up take her off the board, and pull out my cheapo Chinese black 341a I had from a long while back.
    what could go wrong at this point?
    I'll tell you... I drop the programmer with my chip installed to floor by accident whilst moving across the room. and well lets just say I am so angry at myself. so close to having a backup but then breaking the thing just before.
    So my question is...
    How Can I salvage this chip to get a dump of my bios?
    here is the pic of the disaster board....
    thanks for listening.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11682
    Re: Surface Pro 6 - Physically Broken Bios Chip
    https://www.badcaps.net/forum/showpo...5&postcount=10
    • Evostar
      • Jun 2022
      • 5
      Hi!, and thank you! (first 6 bios I could find) but surely it can't be that easy using a random bios file?
      I need to try dump my broken chip for the serial etc data?
      which pins on the bios chip are used for programming. (with y luck its both those that are broken....)
      • hoaca388
        Badcaps
        • Jan 2022
        • 11682
        All 8 pins, but the chip broke, that's impossible.
        • Evostar
          • Jun 2022
          • 5
          yikes... ok I will stop chasing that route.
          I write down my windows key and took photos of my system about screen. assuming I could as best try transfer manually as much detail as possible to new chip by editing..
          I will keep reading and broken my knowledge. before I attempt
          thanks for your quick reply mate
          appreciated.
          • Evostar
            • Jun 2022
            • 5
            Would anyone care to help me find info on specifics for changing Bios for Serial, touch, Windows key etc on Microsoft Surface Pro? many thanks
            • JoWed
              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
              by JoWed
              Hello Community,
              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
              07-01-2025, 09:32 AM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
            • inck243
              Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
              by inck243
              Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
              The BIOS...
              07-25-2024, 09:17 AM
            • Azurain
              Elitebook 840 G5 Bios Chip Soldering Question
              by Azurain
              I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
              Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
              04-14-2023, 06:58 PM
