Dell Microsoft autopilot issue
  • Sparo
    Quicksilver
    • Jan 2022
    • 4879
    • M\A
    • Anime, Edge Computing, Football, Snooker
    #161
    Thank you for the feedback, and You're Very Welcome!
    Regarding the other machine, it's probably not worth continuing with BIOS modded files, since there may be more involved than just BIOS modification (CPU ID)
    You'd likely need to change all identifiers (MAC, SNID, Disk S/N, UUID, etc.). I've seen cases where even after doing that and flashing the EC chip, the lock still remained
    Which could suggest deeper hardware-level restrictions (CPU or platform-level). That's why I asked to discard all mods and install win Home or use Rufus to install Win Pro
    P.S: The reason why I said you NEED to change ALL identifiers and not just one or two is because of how the Hardware Hash logic (Device Hardware ID) works. This is the most important "Autopilot" identifier and it acts as a device fingerprint, but it doesn't do an exact match, it does a fuzzy match. So changing any of those identifiers alone and it still matches, because it doesn't require a 100% identical hash, it just looks for sufficient similarity across all the components. That's why you need to keep changing and keep trying
    Enjoying our forum? Subscribe to unlock extra perks!
    >> Upgrade here <<
    • m1ch43lzm
      • Mar 2019
      • 3002
      • Peru
      #162
      https://learn.microsoft.com/en-us/au...rd-replacement
      Hardware hash is based on:
      • DiskSerialNumber.
      • SmbiosSystemSerialNumber.
      • SmbiosSystemManufacturer.
      • SmbiosSystemProductName.
      • SmbiosUuid.
      • TPM EKPub.
      • MacAddress.
      • ProductKeyID.
      • OSType.
      Scroll down to Specific repair scenarios, there may be a hint in there
      • yaso143
        Dell 3390 os booting issue
        by yaso143
        Hello, I need help with a Dell Latitude 3390 OS booting issue.
        The unit powers on normally, and BIOS loading time appears normal.
        However, when the device boots into the OS, a black screen appears, but the mouse cursor is still movable.
        SSD health is normal.
        I already reimaged the OS, and boot times appeared normal afterward. However, once Windows updates are installed and the device restarts to complete the updates, the issue returns.
        I also tested using a known-good SSD and performed a standard OS reimage, but the issue still returns...
        05-14-2026, 08:42 AM
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • hazem3636
        need Bios Bin file Dell server 220
        by hazem3636
        hi everyone
        i need dump file for dell server r220
        i have download Flash BIOS executable file but i dont know how to conver it to Bin file
        i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
        if anyone has this method please need his supporting .
        all the best
        EXE file is attched and Original Bin file from the Bios Chip is attached also
        and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
        11-05-2022, 06:20 AM
      • Ven
        Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
        by Ven
        Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
        Issue Description:
        1. CPU Overheating to 100°C
          • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
          • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
          • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
          • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
          • Thermal
        02-12-2025, 03:57 PM
