Asus x512d
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Originally posted by hoaca388
    Serial number : KAN0CV05N714416
    Thank you again. Hope this bios works ... can you tell me how do you repair bios?
    Never stop LEARNING because life never stops TEACHING!
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Updates: Bios that you provide doesn't work,
      Result: 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
      I already replaced the RT8249CGQ responsible for the 3.3v AO voltage to turn on IT8225e-128
      Installed the original bios to my unit
      Result: 19v main , 3.3v VCC in IT8225E-128, EEPROM VCC 1.8 volts and the charging voltage 6.7 volts
      need enable signal from IT8225E-128 to turn on the 5v and 3.3v coil of RT8249CGQ.
      Need a clean ME bios dump of my original bios.
      I don't have programmer tool for EC to program the IT8225E-128 KBC.
        • 20455
        There`s nothing wrong with the bios that hoaca388 posted. Flash it again, to the same 1.8V bios chip and double check your soldering. Doesn`t make sense why VCC would be 0 volts
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          thanks for the reply.. Gonna flash it again with hoaca388 provided bios bin and post later the result.. thanks for the patience.​
          • dahm
            • Apr 2018
            • 23
            • alger
            I need the BIOS file for an ASUS x512D laptop.
            x512dk rev:2.1.
            The label reads 60NB0LZ0-MB1710.
            SN: 24M
            K5N0CV015475189​
              • 20455
              x512dk rev:2.1.
              SN: 24M
              K5N0CV015475189​
              Thread merged. Post a picture of the long barcode sticker on the motherboard
              • dahm
                • Apr 2018
                • 23
                • alger
                #27
                thank you
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11402
                  • Viet Nam
                  #28
                  thank you
                  X512DA
                  • dahm
                    • Apr 2018
                    • 23
                    • alger
                    #29
                    X512DA
                    The rest of the same problem, black image, and when I press the stop key, it works again by itself
                    • boneco69
                      • Jul 2010
                      • 4
                      #30
                      Posted wrong on X512DA thread, i am restarting here and kindly ask moderator to erase my post there.
                      I have an Asus X512DK (board with only APU) that is powering right away on dc-in voltage from bench supply. CPU start to get hot very fast and then in about 1 minute the fan start to spin. All voltages seem to be good. Current not changing much (dont remember values but are around 500mA). I think this is a case from a corrupted BIOS chip (from Windows Update Mallware).
                      S/N: K3N0CV10R13613B
                      Attaching the needed images and file. Cannot upload .bin nor .jpg - created ZIP with all files (in the other thread i missed the internal QRCode and Board Version - it is V2.1).
                      Best regards.
                      • lapfix
                        • Mar 2020
                        • 2636
                        • my workshop
                        #31
                        Try this virgin file
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11402
                          • Viet Nam
                          #32
                          Best regards.
                          X512DA
                          • boneco69
                            • Jul 2010
                            • 4
                            #33
                            X512DA
                            Firstly thank you for the BIOS file.
                            I can only flash the UEFI yesterday. It seems that is doing the same. I will try to reheat (from bottom) the cpu and see if the system boots to UEFI. Strangely if i remove the BIOS chip, the system will not power up - i could think this UEFI BIOS chip will not be needed to EC in case of BIOS reset (by not connecting battery nor AC adapter/power supply). So maybe the problem is somewere else in this motherboard. I will report when there is more time to see this.
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • lrouw84
                              by lrouw84
                              Hi there,
                              01-28-2023, 01:31 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
