Asus x512d
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Originally posted by hoaca388
    Serial number : KAN0CV05N714416
    Thank you again. Hope this bios works ... can you tell me how do you repair bios?
    Never stop LEARNING because life never stops TEACHING!
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Updates: Bios that you provide doesn't work,
      Result: 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
      I already replaced the RT8249CGQ responsible for the 3.3v AO voltage to turn on IT8225e-128
      Installed the original bios to my unit
      Result: 19v main , 3.3v VCC in IT8225E-128, EEPROM VCC 1.8 volts and the charging voltage 6.7 volts
      need enable signal from IT8225E-128 to turn on the 5v and 3.3v coil of RT8249CGQ.
      Need a clean ME bios dump of my original bios.
      I don't have programmer tool for EC to program the IT8225E-128 KBC.
        • 21620
        There`s nothing wrong with the bios that hoaca388 posted. Flash it again, to the same 1.8V bios chip and double check your soldering. Doesn`t make sense why VCC would be 0 volts
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          thanks for the reply.. Gonna flash it again with hoaca388 provided bios bin and post later the result.. thanks for the patience.​
          • dahm
            • Apr 2018
            • 35
            • alger
            I need the BIOS file for an ASUS x512D laptop.
            x512dk rev:2.1.
            The label reads 60NB0LZ0-MB1710.
            SN: 24M
            K5N0CV015475189​
              • 21620
              x512dk rev:2.1.
              SN: 24M
              K5N0CV015475189​
              Thread merged. Post a picture of the long barcode sticker on the motherboard
              • dahm
                • Apr 2018
                • 35
                • alger
                #27
                thank you
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12247
                  #28
                  thank you
                  X512DA
                  • dahm
                    • Apr 2018
                    • 35
                    • alger
                    #29
                    X512DA
                    The rest of the same problem, black image, and when I press the stop key, it works again by itself
                    • boneco69
                      • Jul 2010
                      • 7
                      #30
                      Posted wrong on X512DA thread, i am restarting here and kindly ask moderator to erase my post there.
                      I have an Asus X512DK (board with only APU) that is powering right away on dc-in voltage from bench supply. CPU start to get hot very fast and then in about 1 minute the fan start to spin. All voltages seem to be good. Current not changing much (dont remember values but are around 500mA). I think this is a case from a corrupted BIOS chip (from Windows Update Mallware).
                      S/N: K3N0CV10R13613B
                      Attaching the needed images and file. Cannot upload .bin nor .jpg - created ZIP with all files (in the other thread i missed the internal QRCode and Board Version - it is V2.1).
                      Best regards.
                      • lapfix
                        • Mar 2020
                        • 2756
                        • my workshop
                        #31
                        Try this virgin file
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12247
                          #32
                          Best regards.
                          X512DA
                          • boneco69
                            • Jul 2010
                            • 7
                            #33
                            X512DA
                            Firstly thank you for the BIOS file.
                            I can only flash the UEFI yesterday. It seems that is doing the same. I will try to reheat (from bottom) the cpu and see if the system boots to UEFI. Strangely if i remove the BIOS chip, the system will not power up - i could think this UEFI BIOS chip will not be needed to EC in case of BIOS reset (by not connecting battery nor AC adapter/power supply). So maybe the problem is somewere else in this motherboard. I will report when there is more time to see this.
                            • boneco69
                              • Jul 2010
                              • 7
                              #34
                              -- Ok. My bad. The problem was an shorted capacitor near BIOS chip, next to the litle IC or transistor (3 pin). The small capacitor was only detected faultry with infrared camera, because of head from the IC/transistor near it. Strangely all voltages, except in that line not related to any coil, are apparently ok. It is a case for a BadCap! This is easy to occur beacuse this motherboard zone is in the ventilation grid openings and moisture can give this results.
                              • razor_amd
                                by razor_amd
                                12-15-2020, 07:07 PM
                              • grimacelord
                                by grimacelord
                                07-10-2025, 02:52 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • throwaway327
                                by throwaway327
                                Model No: RC72LA
                                Serial No: SBNVKD001014459
                                06-18-2025, 05:52 PM
                              • lrouw84
                                by lrouw84
                                Hi there,
                                01-28-2023, 01:31 PM
