Asus x512d
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Asus x512d
    I need a workng bios on this model Asus x512d , laptop suddendly not working check all voltages present, and theres is 1.8v on pin 3 7 8 of the bios chip anyone have a working dump please
  • mon2
    • Dec 2019
    • 14631
    Re: Asus x512d
    1v8 for a flash bios chip is normal these days. It is very possible that your flash device is truly designed to operate @ 1v8.
    What are the full markings on the flash device ? With this detail -> search for the datasheet and review the voltage range for the Vcc parameter = power rail. Respectively, the I/O pins will also toggle at the same max voltage value.
      • 21606
      Re: Asus x512d
      That QR code is the heatsink part number. Is there a long white barcode sticker on the other side of the board near the soldered ram.
      If there are no stickers post the silkscreened part number, such as X512DK Rev
      • String2016
        • Nov 2015
        • 2238
        • philippines
        Re: Asus x512d
        @smdflea here is the info sticker please thanks for the response
        • hoaca388
          Badcaps
          • Jan 2022
          • 12240
          Re: Asus x512d
          ASUS Vivobook 15 X512DK
            • 21606
            Re: Asus x512d
            You didnt post your bios backup.If you want to add your DMI use Asus Block Transmit tool (WBT.exe windows version) https://www.badcaps.net/forum/showpo...43&postcount=5 ,or you can add it with a hex editor from your backup. If there is a win key its best to add the dmi from your backup .
            • String2016
              • Nov 2015
              • 2238
              • philippines
              Re: Asus x512d
              Tried it still there is no light 1.8v on pin 3 7 8 on the bios chip is present and there is 3.3v on keyboard switch , history of this laptop battery drain then suddenly not working,I have attached original file ec is IT8225E
                • 21606
                Re: Asus x512d
                battery drain is unlikely to be a bios problem.If there is no cmos battery then the main battery is used as cmos for the RTC .
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  Re: Asus x512d
                  Already tried removing and plugging back in still no light when charger plugged in
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    Re: Asus x512d
                    amp draw is 0.006
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      Re: Asus x512d
                      does anyone have a EC on this i will try flash ec
                      • peste
                        • Dec 2016
                        • 13350
                        • ROMANIA
                        Re: Asus x512d
                        Bios and EC extracted from the Asus site update
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          Re: Asus x512d
                          thanks but i have a prolem programming ec using svod 3 ITE not detected
                            • 21606
                            Re: Asus x512d
                            @mcplslg123 to the rescue https://www.badcaps.net/forum/showth...light=svod+ITE
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              Re: Asus x512d
                              Thanks already done that but there is the problem cannot write the chip it says write false, maybe this kbc is faulty
                              • redman13
                                • Aug 2016
                                • 66
                                • bangkok
                                Re: Asus x512d
                                Thank All
                                • Duranitron
                                  • Jul 2014
                                  • 544
                                  • Philippines
                                  Good Day! Need bios dump of Asus x512D mobo.X512DK
                                  or clean me
                                  Thanks in advance!
                                  attached is my original Asus x512d bios dump
                                  Never stop LEARNING because life never stops TEACHING!
                                  • peste
                                    peste commented
                                    Editing a comment
                                    merged post..
                                • peste
                                  • Dec 2016
                                  • 13350
                                  • ROMANIA
                                  or clean me
                                  Thanks in advance!
                                  post S/N..
                                  • Duranitron
                                    • Jul 2014
                                    • 544
                                    • Philippines
                                    Originally posted by peste
                                    post S/N..
                                    can find the S/N of the laptop..
                                    Model: x512dk rev 2.1
                                    P/N: 60NB0LY0 - MB1161
                                    19v main , 3.3v VCC in IT8225E-128 and EEPROM 1.8 volts are present.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12240
                                      Serial number : KAN0CV05N714416
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
                                      • lrouw84
                                        by lrouw84
                                        Hi there,
                                        01-28-2023, 01:31 PM
